charles06
Re-gearing your truck should be considered essential when going with larger tires. Can you get away with running slightly larger tires and not getting new gears? Yes. Is it ideal? No. When you change tire size, you essentially change the gearing of the whole drivetrain. And a hand-held programmer is not going to make it right. It may make the speedometer a bit more accurate, but it's not going to change the drivetrain.
Trucks/cars are made to operate at a certain powerband with certain gearing. When you change tire size, you should also change the gearing to get the powerband closer to stock. Otherwise, your powerband, shifting, MPH, MPG, etc, are all thrown off. I have a Hummer H2 on 40" Toyo's. When I changed the gears to 4.88's, it was a whole new truck. And according to a GPS, my speedometer is only 1-2 MPH off. Considering most speedo's aren't terribly accurate anyhow, I'll take it.
If you go with 37's, I feel that changing to 4.56's would be the way to go. It is important to note that with 4.56's, you won't have the off-the-line grunt as described above by the gentleman running 4.88's, but you WILL have lower RPM's while cruising. It is also important to note that as you go lower in gearing (higher number), you also give up a bit of strength in the ring & pinion because of the number of teeth. The gear sizes discussed here won't have this issue, but when guys go with 5.13's and up, this is always a concern.
Hope this helps.
Charles
Hope this helps.
Charles
