37" Tires on Raptor.
Fillmore2436
Mine have been fine off road so far. I don't ever plan to jump it or race the Baja either. I have to do full wheel lock every day out of the driveway as well, no issues.
2014 Raptor owner wanting to upgrade to 37’ tires. Good to know youve had no issues. We’re you able to keep the stock wheels or no? Thanks.
Aaron
Meme Corps Commandant
WA
Stock wheels fit 37's better with stock fenders. Methods and other 0 offset wheels push the tires out a bit and will cause more rubbing. I had zero rubbing on 37" Baja KRs with stock wheels, but when I put my 0 offset KMCs on I had to trim the flares a bit more.
brc misfit
nor cal
same,,, no issues with 37's on stock 17's at mid.
daveypetey
Stock wheels on K02 37" (they really are 36") with geisers at low perch, +1 deavers in back. No rub, even at full lock. She sees dirt once a month and I've never had issues.
DP
nbg-mustang
Okay I try to find Information but didn`t find anythink. Does real 37 s fit with Fox 3.0 on the front? If I jump or offroad hard, is pinch weld needed? Or does it fit with no needed pinch weld?
Do I need any updates on the rear? Fox 3.0 and stock leaf springs?
Thank you
Daniel
glamisrider
Santa Ana
Thank you
Daniel
37 are going to rub with any off-road usage. The rear is good. ff9d1838e0c228f0efd8d46ac55dc534.jpg
