37" tire guidance please!
rayofsi
NYC
i run the 57trans-x 18x9 0mm offset, debating 37" now. Seems like selection of 37" tires is much less with 18" wheels. Have my +2/+2 fenders and bedsides done and 35" looks a bit off. I believe the 37" add right about 1" of height to the truck vs most 35" tires? also geared for 4.56 already. bolt on performance so far.
snt505
CO
Yeah the tire situation for 37s on 18s was a little interesting. 37x13.5x18 are significantly cheaper than the 12.5 versions and seem to be more available. Decent bump up in price from 17 to 18 on 37x12.5.
rayofsi
NYC
thinking of dropping back to 17" wheels for more selection (the gen3 raptor oem 37" tire), but i need to find some nice lugcentric wheels to clear my currie rear end
Space Ghost
FL
bumping this cause in most other 37 threads not many or if any at all run them with the stock wheel. Most people goin to 37s go to a wider tire (like in that vid) and/or go to a more negative offset wheel.
Saw @Nex run them with stock wheels, but curious if others have done so and whats the situation like with them.
Cause had a similar situation with my ranger tremor, ran 33's on them but cause of the more offset wheel they rubbed on bumps, on stock wheels i had no rubbing. Kinda hoping i can get away with running the FRS 3.0s up front with the factory 1" preload (or just upgrade the springs on stock shocks) and run the 37s hopefully offroad. Was thinking either the K02s or Cooper AT3s in 37 since i think those run smaller and are light.
Nex
RIP CoronaRaptor
Washington State
I bought the truck with BFG 37s on the factory 2018 wheels. Geisers and Icons already on the truck. Switched to zero offset Methods a few weeks later. Had to do the pinch weld mod and trim fenders. I didn't push it off road on the stock wheels so not sure if they rubbed or not.
You can install the shocks and test. See how it rides and if it rubs. You will probably need to do the pinch welds and fender trimming.
People go to the zero offset due to aftermarket UCA or fill out the fenders more. Not because of 37s.
FP_RPTR
California
Most 37 fitment issues are related to the wrong offset or big, wide, and heavy 37s. All the BFG 37s on factory wheels or wheels with similar offset are not an issue on a leveled truck.
What is the ideal wheel offset. I have 17x8.5 0 offset.
FP_RPTR
California
I guess my question... Which it seems like it would reading this thread.. 17x8.5 zero offset will work with 37s. Minor trimming and miner off roading.
shigman
Cypress, TX
I ended up going with some +25 Methods, pushes the tires out a little but nearly stock. I've had rubbing issues on 3 other vehicles with bigger tires and I'm not going down that road again.
