37 KO2 narrower than stock '35' KO2?
Truckzor
Well, there goes all hope for humanity.. Not trusting what a complete stranger tells you on the internet. It spells doom for our society. You are probably just mad that my 35L ecoboost displaces more than your .62 L ! A difference of 1meter/pound of cubic centijoules!
And yeah, still going to overlook the 37 BFG because due to the coefficient of sliding friction. Don't let me have to break down those numbers:ROFLJest:
I'm lol'ing over here. Just get the ******** "37s" and quit with the $2 words, will ya?
ChevyChad
What all is needed to be able to go to 37's? I had 37" on my gen 1 raptor, but it had front leveling done and also had an ADD front bumper. Would i need to do the same things on my gen 2? Anyone have 37's with all else being stock?
castine917
Caledonia, Mi.
Checking out some specs on some future 37's. From The Rack it shows that the 37"
KO2 has a .2" smaller section width than the 35.
This is surprising as I would not want to diminish the footprint when going to a taller tire.
LT315/70R17
113/110S C
Ford
None 2,535 lbs. 45 psi 15/32" 65 lbs. (rim)8-11" 9.5" (section width)12.7" (tread width)10.6" 34.4" (revs/mile)604
37X12.5R17LT
124R D
None 3,525 lbs. 50 psi 15/32" 71 lbs. (rim)8.5-11" 10" (section width)12.5" (tread width)10.5" 36.5" (revs/mile)569
Any astute tire people out there think this is a typo or was the 35" KO2 for the Raptor made so specifically that the tread was increased?
Change of tire pressure in specs could account for width.
dude1782
PHX, AZ/SLO, CA
SVCOFFROAD C.A.S. Coil Adjustment System
https://r.tapatalk.com/shareLink?sh...forum.com/showthread.php?t=51446&share_type=t
Sent from my 2017 Raptor using Tapatalk
---------- Post added at 06:36 PM ---------- Previous post was at 06:34 PM ----------
Installed SVC's Coil Adjuster System
https://r.tapatalk.com/shareLink?sh...forum.com/showthread.php?t=52906&share_type=t
It costs quite a bit more than the RPG one but it's adjustable and you might not have to do any trimming depending on your wheel and tire combo
