37" BFG ATs
Ramrodthrusterpuppy
Ottawuh, Canaduh!
I've been running 37/12.50/17 BFG ATs on OEM beadlocks (mid perch) since last Fall, mild off-roading (no jumps), Winter driving....no rubbing issues at all. Personally, I firmly believe wheel offset is the key to rubbing or not with little to no other modifications. I'm not sure that a 0 or negative offset wheel wouldn't rub, but I may run small spacers (~1") with my beadlocks just to get a *little* more wider stance. I don't think I'll go back to my 35" Toyo M/Ts on ProComp wheels for the Summer....which sucks, 'cuz I just bought them last year! Lol!
BAJASVT
SE Michigan
Thanks, Ramrod. I've heard enough... I'm ordering these.
Are you running the OEM wheels in stock configuration with the beauty ring or do you have the Ford Racing beadlock ring installed? This is an 8.5" wide wheel, but I feel a 9" width would more accurately describe the width when the Ford Racing beadlock is installed due to the tires outer bead technically being mounted outside the factory seat. I know a few members here have installed the Ford Racing beadlock ring on the OEM beautylock wheels; I'd be curious to know if anyone took a tire height measurment comparison between OEM beautylock and Ford Racing beadlock. Other members are measuring an actual ~36.3" diameter on these tires... I'm guessing the Ford Racing beadlock would fatten the tire slightly, but pull that ~36.3" down to about ~36.0", which is fine with me (less chance of rubbing).
Also, have you shopped around for spacers? What have you found? There's another thread floating around where someone found some hubcentric 6x135 spacers, but they're 1.5" thick. If you only run 1" spacers, I'm pretty sure you'll need to grind down your OEM wheel studs or replace them with shorter studs or they'll protrude through the 1" spacer to the mounting face for the wheel hub.
Please keep us updated.
vince7870
long island NY
with the 37's are you guys getting computer reprogrammed by ford to correct speed and shift points? is that even an option? is anyone changing gearing? is that necessary?
Hockster
My 45ft Bluewater Party
Winchester, Va
Well, if you change to 37 tires you should change your axle ratio to 431 or so but they dont make that gear so best would be 456 to get close to the 410 gearing.
BAJASVT
SE Michigan
Agreed!
A lot of guys running older Ford trucks w/ the 4.6L or 5.4L are running 4.56 gears with 35" tires, but the 6.2L can get away with a 4.10 because of it's additional torque. Like Hockster said, even with a 6.2L and a 37" tire, something with a higher ratio than 4.10 would be ideal. For those with a 2010 and a 5.4L, I'd recommend 4.56 gears if you're running a 37" tire.
TheJoker
N. E. Massachusetts
So what I think we agree on, is that the 6.2l could get by with the stock 4.10 gears with 35"-37(36.3)" tires. But, ideally you would be better off with 4.56 gears? Now who makes them and where is the best place to buy them? Also, I'm guessing that the front gears for the 2010-11 and the 2012+ would be different?
