3 Days into having a dash cam, recorded my first crash
goblues38
goblues38
STL
rear mounts on the drivers side because the power window moves to the passenger side.
I did not take a picture of my install...but I dont even know it is there...front or back
every camera is different....but at 1080p 30 frames / sec for both front and rear, i can get 12 hours of recording before things start to be overwritten....that is using a 128gig card......do the math, or google the values for smaller cards
RaptorMaryland
Maryland
Mini0906 front and back cams installed. The red circle is the ferrite clamp on the rear cable, as it interferes with fords TPMS system.
Ferrite bead does the job of blocking the interference coming from the connection joint.
