3.0's, bumps and nitrogen
pat'sRAPTOR
Everywhere
So is this something that needs to be tightened? I've run hard with this setup for awhile and never had an impact between bed and cab until last week. So I just figured it must have been because low psi in the bump stops.
---------- Post added at 12:54 PM ---------- Previous post was at 12:53 PM ----------
Almost. One had like 30 psi.
The only way to keep the cab from moving is putting solid mounts in and that will make for one very rough ride!! The cab mounts keep the rough stuff from making it to your seat lol it's just one of those things haha the bed does move a little but the cab does most of the moving you could slightly notch the bed holes where it mounts and slide it back about a half an inch to keep it clear but that wouldn't look very good!
Madcowranch
Genetically Modified
OK
The only thing is I've run harder than I did last week and it's never been an issue.
So something has changed.
pirate air
will plunder your booty
The bed and cab has always hit on mine. Before and after the bump stop kit.
2manytrucks
Florida
One thing to keep in mind when you are checking nitrogen in your shocks...
If you are only checking the nitrogen pressure in your shocks you are going to lose pressure. There is a lot of pressure confined in a very small space inside the reservoirs and when you are attaching a gauge to the schrader valve you are opening the valve and will probably lose around 40-50 psi.
The only way to really "check" the pressure without losing any nitrogen is to use a no loss air chuck attached to a nitrogen fill tank with a regulator. I normally recommend simply emptying all of the nitrogen from the reservoir and re-inflating the shock to the recommended PSI.
These are the no loss air chucks we use, they work really well.
We also have these Nitrogen Shock Inflation Kits on the shelf.
Jason, let me guess MAP on these?? I have never seen a group buy on these kits?? Any possibility of the kit shipped for around $400 with a certain quantity sold?
