2025 Forscan
Edwin
Albuquerque, NM
Hey all, just picked up a 2025 801a from a 2020.
I noticed the Forscan SS only goes to 2024, anyone tried making changes with this SS?
Also, is there a way to get the truck to remember the drive mode and exhaust setting on startup? i.e. always be in Sport Drive Mode and Baja Exhaust mode.
Thanks!
Hemkin57
Bumping this up to the top. Wondering if anyone has done Forscan on a 2025 yet. I just moved up from a 2017 to a 2025 802A and the seat belt chimes are way too aggressive.
RaptorFun
Northeast Wisconsin
I could not turn off the seatbelt chimes on my 2024 Raptor using FORScan. There is a procedure to turn them off and back on. It may be detailed in your owner’s manual or you can find it by searching on the Internet. I went this route:
They work as advertised on my newly acquired 2025 Raptor.
Darkwhip
Tri Cities TN
This worked on my 2024:
How do you turn off the seatbelt chime on a 2024 Ford f150?
Turn key on (do not start), wait until air bag light goes out, wait 3-5 seconds, then buckle and unbuckle the seat belt 4 times, ending with it unbuckled, wait for seatbelt light to flash and then stay on, then buckle and unbuckle one more time.
RaptorFun
Northeast Wisconsin
Great info! However…do the red seatbelt not buckled symbol(s) disappear after disabling the chimes with the seatbelt(s) unbuckled?
Mine didn’t. That’s why I went with the mini extenders.
Darkwhip
Tri Cities TN
^ I only have the small symbol on the bottom right of the gauges showing solid. I can ignore it as the dash on these trucks have so much screen and so many symbols light.
aikejiri
Seattle, WA
Hi. I just used forscan on my 2025 raptor 801A. I looked at the spreadsheets that are posted online and used anything referencing the 2024 models! Seatbelt chime disabled, parking lights on with DRL, walk away lock, etc. worked like a charm!
aikejiri
Seattle, WA
Thanks!
I don’t believe so! The only thing is you can always start it on quiet mode . Other than that, start the truck up and change the exhaust mode on the steering wheel.
Edwin
Edwin
Albuquerque, NM
Last time I tried using FS on my 2025 was a few weeks ago but couldnt make any changes yet do to the FS database not being updated yet.
