2024 Raptor Quality issues
alockbox
US
Two small bolts at the last hanger. Loosen, push up, tighten back
This is the suggestion I see everywhere but it only adjusts the vertical height of the exhaust. In my case, the passenger side one is lower AND further out (sticking out past the bumper) than the driver side one. I can't find an easy adjustment for that, as the pipe bend seems to be a little off.
Subaruski
PNW
No issues on my 802a so far aside from this random screw laying on the drivers side floor one morning.
I tried looking under the dash to see if I could find where it came from but no luck.
TheC-Don
Atlanta GA
Just go upstream and loosen exhaust clamps. You can pull them in and out.
alockbox
US
Thanks. I must be doing something wrong. They don’t seem to budge. Maybe I need to loosen more than one going even further back? I’ll check again when I’m back in town.
Rockbuster
Correction: My bumper is also a bit low on the passenger side...which means my exhaust is a bit low on the passenger side. Annoying.
DFS
USA
at least Toyota actually admits fault and recalls things. Ford has been decent about customer sat programs. many years later after years of denial.
It's been awhile since Ford had spun main bearings, which Toyota so far has only offered short block rebuilds not even replacement. I'd be demanding a long block replacement if it was my Raptor, there's no way they are going to clean these of all the debris at the dealership level. Toyota has not handled this well so far if look into it more.
Edit: Not to mention this is likely the NHTSA forcing Toyota's hand at this point, not Toyota being some forthright company that only cares about the consumer. Their remedy will be telling.
dsiggi
Detroit
ey eye eye..... no fun
