2022 Upfitter Switch 1 Not Working
R
raptor_nj
NJ
All the upfitter fuses are good. When I say there is no power to the tail, I mean to the factory plug/the light.
I am not sure if you have seen the diagram I attached to this reply, but any ideas would help.
Antho
Yeah, I literally posted the diagrams in the post before yours. How are you connecting the lights? Do your lights have the for connectors to fit the factory wiring? You have power at fuse 62 but not at the factory fog connector? Pictures of the wiring? What color are the wires at your fogs?
Littlefx4
Pretty sure the kits from Baja designs intends for the 2 squadrons to be run off a relay direct to battery. I don’t think the factory wiring is rated for that amperage. The fog light kit I got from them came with wiring to do it this way. Maybe you blew the fuse?
This. Definitely check that amperage to be sure you can run all 6 on that switch. I think it may be too much. You could get by using switch 2 or 3 for all six. You may want to re-attack this and use separate switches. But if you’re dead set on using that 10 amp switch, consider running a relay.
R
raptor_nj
NJ
Yes, there is an adapter to connect the Baja Designs lights to the factory harness. Yes, there is power at fuse 62 and not at the fog connector. See photo showing the factory fog connector with the brown/green wire.
New recaros
Colorado
Maybe the work with the auto headlights. Turn you’re headlights on in manual and see if you have power
Antho
They should have power when the ignition is on or in acc regardless of the headlamp switch. If the ignition isn’t on, you won’t have power.
Littlefx4
As I suspected, each light is rated at 2 amps so running all six on switch 1 won’t work. I’m surprised you didn’t blow the fuse. Or perhaps I’m not understanding how you‘re trying to set these up…
R
raptor_nj
NJ
I am only trying to run four on switch one and two on the factory fog switch.
As a side note, switch 1 is supposed to be rated for 15 amps
Littlefx4
And there’s your problem. Gen 3 switches are setup different from Gen 2 switches as follows…
Gen 3
switches 1 & 4 @ 10 amps
switches 2 & 3 @ 15 amps
switches 5 & 6 remain the same @ 5 amps
edit to add the factory fog is 10 amps.
Hope this solves your problem.
Littlefx4
If you purchase SPV’s factory fog relocation harness, you can route those 2 wires from the bumper up to the bundle of 5 behind the battery for better access. Just throwing that out there.
