2021 Gen 3 Eibach Front Leveling Springs
nirazulay
Israel
Geiser gave me an updated timeline of sometime in October and Eibach is saying sometime after September. Geiser is done prototyping and in production but Eibach is still in testing.
What are the differents between them? I need to level ip mostly the rear of the track and also plus 200 lb extra in the bed permanently
Bruichladdie
Kentucky
Don't quote me on this but from what I've heard regarding Gen 2... Eibach is better on the street and geiser is better offroad.
Geiser is only offering a 2.5" front and a slightly heavier duty 1.5" rear
Eibach will have a level front spring, a lift front spring, a rear lift spring and an HD rear spring.
Kind of pick your poison. I personally am gonna go with geiser once his rears come out. I prefer to support a small business in the offroad community and I've never heard anyone complain about them personally.
DMays
Tennessee
I’ve been waiting for these springs and now that they are out it sucks they don’t work on a 37pp truck. Hopefully eibach will fix that.
broke1
Tucson, AZ
Yeah, sounds like there's not enough rough for the Gen 3 35inch spring diameter in the 37 suspension setup. Hopefully they'll come out with a new set of narrower front and rear springs for the 37 and upcoming R (presumably the same suspension).
FmaxTurboSi
So Cal
ordered the leveling springs. i'll be getting them powdercoated before install. Also just got the forscan cable to recalibrate the shocks after install. I'll keep ya'll posted.
Chuckaroo91
Boise, ID
Do you need to recalibrate? I thought on the Geiser site it says the truck automatically adjusts when started?
FmaxTurboSi
So Cal
I can’t imagine the truck adjusts automatically when started, cuz what if the trucks not on level ground at startup? I know my truck isn’t cuz it’s parked at a slight angle on my uphill driveway.
I could be wrong tho.
Idaho Savage
USA
I don’t know but I doubt the truck cares. It’s calibrating the shock travel which has nothing to do with a level surface. I’m guessing it “learns” the new normal over the course of driving it?
FmaxTurboSi
So Cal
I thought you’re calibrating the ride height of the truck? Like where “0” lift and “0” lower would be? Cuz the ride height sensors are attached to the upper A-arm.
