2021 AB 37 PP - 38's Upgrade
ToadSmasher2K1
Home Is Where You Make It
Red Kingdom
They’re more than likely E rated if they’re 20’s. That’s the source of the rough ride. Lowering the pressures might help slightly, but E rated tires blow.
Christian92
Christian92
What are the tire pressures set at?
Tire shop installed at 46 at that was too much since the sides weren't touching pavement, so I changed them to 40. I do see some sag though so maybe going to test 42 and see if that's a happy middle ground.
Nex
RIP CoronaRaptor
Washington State
That's still to high. I am running 32F/30R on my 37s. Some run lower.
