2021 AB 37 PP - 38's Upgrade
ToadSmasher2K1
Home Is Where You Make It
KC
They’re more than likely E rated if they’re 20’s. That’s the source of the rough ride. Lowering the pressures might help slightly, but E rated tires blow.
ToadSmasher2K1
KC
12 ply + E load + 90 lbs each = poor ride
38’s look good though
Christian92
Christian92
What are the tire pressures set at?
Tire shop installed at 46 at that was too much since the sides weren't touching pavement, so I changed them to 40. I do see some sag though so maybe going to test 42 and see if that's a happy middle ground.
Nex
RIP CoronaRaptor
Washington State
That's still to high. I am running 32F/30R on my 37s. Some run lower.
