Oldfart
- Joined
- Oct 21, 2017
- Posts
- 6,077
- Reaction score
- 15,173
Since you are clearly not speaking in hyperbole, I'm shocked most other Raptor owners simply describe Sport Mode shifting as "harsh" as opposed to being "rear ended". Sport mode does shift hard in my truck as well, but not like you say.
Roger that, Tango Mike. That's why you're Tha Man A Hundred GrandTo clarify, I was referring to the normal shift firmness of the 5-6 shift in Sport mode, not a condition in which there is an actual transmission issue with DTCs setting. When the TCM goes into limp mode, it may turn up line pressure to avoid slipping clutches. The high line pressure is what causes the harsh engagement that you’re describing.
With the transmission shifting consistently poorly and DTCs setting, the dealer should have no issue diagnosing the root cause of the issue. Just explain to them what you wrote in your post, tell them which shifts are hard under which conditions and that multiple warnings lights came on in the cluster.
Is that while driving in Sport mode?
i have a 2020 with 11000 miles. the 1 to 2 and 2 to 3 are very hard and all the rest buttery smooth. worst shifting transmission i have ever drove. makes no sense.
the reason I used hyperbole is to make the point regarding the claim that this is a feature, not a bug, which is that I understand firm shifting in sport mode and holding the gears longer, which is what happens with all the other gears. But from 5 to 6 (not exaggerating this time) its enough to spill your coffee if you are holding it, along with a noticeable thud, literally like a minor rear end collision. And I am not talking while flooring it, I am talking about normal, very light acceleration, as in 0-60 in 20 seconds driving like a grandpa. Anyway, its intermittent, and I stopped pursuing the issue with Ford because I don’t have the time or energy to deal with it. The truck is badass in every other aspect, so not a deal breaker for me.
