2020 Raptor does it have a leveling kit?
blwn
Florida
it does and drives stiff. going to take it to ford and have them removed
Do you like the look of the level? If so you may want to try resetting the Live Valve shocks thru FORscan to see if it makes it ride any better.
A
alangsam1
Florida
it's actually a little higher in the front which i don't like along with the stiff ride.
kind of makes sense that this collar preloads the spring.
Deleted member 12951
Guest
The RPG preload collar is a good thing. I would keep it. Helps with off-roading and prevents the front from being bouncy. You need to get the ride height adjustment recalibrated for the Live shocks, do this first before removing and try it out. But I would also change how the live wire is attached as it shouldn’t be zip tied to the coilover (looks tight). Measure both the rear and front to the top of the flair. How much difference is there actually?
If you want a rake look, You will be better off upgrading the rear to either ICONs or Deavers +3 to raise the rear instead. The rear on these trucks suck in their stock form.
