The only thing they messed with was the pan. If it’s not leaking from the pan, it’s most likely venting fluid. Which is caused by the transmission being overfilled or overheating, and your readings verify it’s not the latter.
Would an overfill situation cause the transmission to jump/slip while cruising in 10th at 75mph? The whole thing is really weird...worked fine for 1k+ miles, then had the exact same scenario except only a drip of fluid coming out.
