2019 Raptor Transmission Fail
HeavyAssault
Virginia
Progressive Range Selection
Progressive Range Selection gives you the
ability to lockout gears from the automatic
shifting range. This may provide you with
an improved driving experience, for
example, in slippery conditions or when
experiencing a steep slope.
With the transmission in drive (D), press
the – button or paddle to active PRS. The
available and selected gears are indicated
on the instrument cluster.
All available gears display with the current
gear indicated. Press the - button or paddle
again to lock out gears beginning with the
highest gear. For example, press the -
button or paddle twice to lock out 10th and
9th gears. Only the available gears display
and the transmission automatically shifts
between the available gears. Press the +
button or paddle to unlock gears to allow
the transmission to shift to higher gears.
The transmission shifts automatically
within the gear range you select.
