Unlikely any issue with either. Trailer must be plugged in or if not plugged in insert the lock out key/pin to prevent the coupler from sliding back and engaging the brakes. If plugged in and the brakes still engage then likely due to excessive angle and you may need to use the lock out key/pin at times even when plugged in. This isn’t a Raptor only issue but happens more often with the softer suspension compressing and causing excessive angle.
