Not yet. I’ve gotta start tracking the weight with all the additional ideas I’ve got floating around in my head to see when it’ll be necessary. It’s definitely coming, but so far it seems okay on stockAs I said on reddit truck looks good man... what I forgot to ask was have you swapped leafs? I'm thinking of going with +3s but won't know for sure til the rci rack gets here
Where are you stationed?I have a similar set up on my Raptor. Only plus to being stationed in California is all the OHV camping areas. I have been looking for a way to attach my shovel to the rack like yours. Where did you get the quick releases for the tools?
Been talking to the wife a bit regarding the whole fridge/cooler/battery situation. I’ve been eyeing that 73qt ARB Zero and figured I’d go solar with deep cycle since I, too, wouldn’t wanna touch main with it.Looks great.
I wired in an Aux battery and Redarc bcdc 1225 charger. A bit of work to get it all set up, but its great. Probably overkill for running some camp lights, charge phones etc., but I run a 55qt ARB fridge and didn't want to touch my starter/main battery.
I have my tent on the lowest of the 18 to 30" of the Overhaul HD rack. At 18, I can just barely stand under it, so can run an annex and a room under my awning, if I want to get fancy. But then more of the tent is in the wind that way too. Re the mpg, I find the extra 200 lbs and wind drag is maybe... maybe 1 mpg. Maybe a titch more with the full camping load out. That is a way better hit than towing a trailer.
Those ladders are a bit of a puzzle. You need to start from the bottom when collapsing the rungs, so that they are stacked up above the top rung. But maybe with yours being closer to the ground you need to do it differently.
As far as weight, I think I will do something like a Deaver + 2 or 3 at some point. The rear is pretty soft and I lose a bit of rear departure angle when fully loaded (around 400 lbs). Still drives nice, but would rather be sitting level.
As promised!Love how it fits flush/slightly below the cab roof line when stowed. Added weight, and may have more drag in the area directly behind the truck, but more streamlined airflow over the bed...curious if you get better or worse gas mileage with the rack/tent in place while cruising.
