TXRaptor
- Joined
- Sep 15, 2010
- Posts
- 1,851
- Reaction score
- 1,048
I definitely need a solution that is either...
A: makes the truck better all around for both on road, Offroad and towing.
B: is removable EASILY after towing.
I spent a lot of time looking for option A, but came up with nothing that does all three. Deaver HDs are pretty close, but your on road comfort suffers over the standard Deaver +3s I have on my Gen 2.
For option B, the Roadmaster Active Suspension is the best choice for towing and everyday driving with easy on/off. I have the SuperSprings for my Gen 1 and they are also great for towing and everyday driving. However, they are a chore to install and remove for your off-road excursions.
Also, just an FYI, the SCAB is only rated at 6000 lbs max, so you should not exceed that no matter what option you choose to reduce sag. That was part of the reason I went with a SCREW for my Gen 2.
