2018 Order Progress
wheelman55
Big Bend or MN
So I never pinged the dealer for my VIN, I check with the FP chat yesterday and here it is...
Frank N says:
Hi I was hoping to check the build date for my order
Matt says:
I need a order # and dealer code, or vin
Frank says:
order # is XXXX and I dont have a dealer coed but a sales code, it's XXXXX
Matt says:
Ok one moment
Matt says:
It shows that it has been sent to the plant for production. You do have a VIN now, but you would need to get it from the dealer.
Frank says:
Thanks Is there a scheduled build date?
Matt says:
It's in production now
Frank says:
Oh I thought they werent starting yet
Matt says:
This is the earliest one I have seen
Frank says:
ok, thanks and have a good weekend
Matt says:
You too
Needless to say I pinged my sales guy yesterday afternoon for a VIN, but have not heard back...and second, I don't know if I can believe it.
Congrats. Sounds like your dealer took good care of you even though they've been slow with the VIN.
Once you get your VIN, you should be able to pull your window sticker from raptor finder. Make sure to show your gratitude and drop some coin into the donation fund for photoneffect. There's a button to click on the raptor finder app to do this. Photoneffect has spent a lot of his personal time working on this for us.
On the top of the window sticker, in the white area just left of center, you'll see the word "BLEND".
Directly above "BLEND" you'll see a number code that tells you your build date. On mine it's: 220170717, which is a July 17 build date.
Directly to the right of "BLEND" in boldface, you'll see a four digit code which is your place in line. Mine says 0222, which allegedly means that my build will be the 222nd build on the line. That would include all F150's going through the Dearborn assembly plant.
From what I read re:"How to read a Window Sticker" this four digit code rolls over, from 0001 to 9999, then begins again with 0001. It shows all vehicles moving through that particular plant.
I've read that the Dearborn plant produces approx 1,250 F150's a day, which is one every 60 seconds. Using that number of builds a day, it'll take roughly 8 days to run through the first batch of 9999 builds, then it'll reset to 0001.
With that info, my build should be the 222nd to start on that first day of production. That would be approximately 2 1/2 hours from the start of production.
I've also read that the build process takes 20 hours. Best guess would have my build finishing sometime on the 18th.
Hope this helps. I'm pretty excited for all of us.
Frank N
NJ and Outerbanks
Maybe it's half assembled on the line but Dearborn is shutdown for vacation...
VACATION SHUT DOWN – JULY 2017:
FOR STAMPING, TRANSIT AND TRUCK SYSTEMS FOR THE WEEKS OF
JULY 3, 2017 and JULY 10, 2017:
A crew will working until June 29, B crew will work until June 30, and C crew will be working until July 2.
A and C crew will return on July 17, and B crew will return on July 18.
Transit last day worked will be June 30 and will return to work on July 17.
ovrlnd
I checked on mine yesterday to make sure that there's been no change in status.
There's been no change in status.
wheelman55
Big Bend or MN
2018 build
Got the "It's in production now" message from Ford chat. Blair referred me back to my dealer for any further information.
FYI. I've allegedly got July 17th as my build date. Blair was not able to see anything other than it's "in production". Nor was he any help when I commented that the Dearborn plant is shut down this week.
This was NOT Ford Performance chat...it was Ford chat. Ford Performance chat is not online right now. I'll try FP chat later in the day.
wheelman55
Big Bend or MN
Ford Performance was a bit more helpful...read below:
kastn4
Kodiak, AK
The dealer said mine is scheduled for a build date of 7/24 and I received my VIN, so just waiting until I can access the window sticker. I have periodically tried to access it through the window sticker search site but it keeps saying that the window sticker has been restricted on this site. Anyone else getting the same message?
wheelman55
Big Bend or MN
Have you tried https://www.raptorfinder.com/
I've heard that the window stickers become available a week or so before production. However mine was available 6/27 for a 7/17 build date.
