GEN 2 2018 , Collision warning not available sensor blocked
Tulsa Raptor
Tulsa Oklahoma
Bumped into a deer the other night at maybe 5 - 10 mph. Almost had it shut down. Deer lived and moved on. Truck, no visual damage, slobber on passenger headlight, body bumped low center of truck. Now I got this flashing periodically, I can click ok but it comes back immediately and won't go away. At times when I run the truck it will take awhile before this starts to occur. There are times where the code will flash on dash but stay gone for long periods of time then come back and start popping up again. Feel like maybe the censors behind the lower bumper cover are mis aligned or loose now. Any thoughts?
T
Tulsa Raptor
Tulsa Oklahoma
I was able to get down in there tonight and found that the silver part of the bumper was bent in slightly, just enough to pop the collision sensor piece loose from its mount. Snapped it back in, one corner, put the black Lower cover back on and no problem. Fixed. Done. One of the collision sensor bolt mounts is located on the silver bumper and was bent upwards and in. I will go back in and straighten that mount item out soon.
HX-6
Lewistown
You can test each sensor with your cell phone. just put your phone in record audio mode and put the truck in a position that would turn on the sensors like reverse or in drive if your checking the front sensor (use a second person so your truck doesn't drive away) and if you hold your phone next to the sensor you will see some audio pulses on the screen, your can't hear them but your phone can. I fixed my Yukon by finding one bad sensor and it was $35 from the auto parts.
