RC51TOFUMAN
Can you do this Mod for me? You make it look soooo easy peeeezyI got the lights delivered a week or so ago they were on back order for a bit. I finally had time to look at the plugs on new ones and i yanked the lights off my 2010. So the plugs are kinda similiar as they use the same exact pins just the housing are diffrent between them , I contemplated cutting off the old plugs and soldering onto new ones . I included a few pictures , i took one of the new ones and used a paperclip with a little hook bent on end to try and pull out the locking deal from inside , but couldnt see how to grab onto it so i ended cutting side of plug out to expose the lock then i could see how to hook and pull the lock out(gray plug) . The black plug from 2010 had red lock deal inside and that was easy to grab onto with paperclip hook and remove it completetly out of plug. Once removed with a flashlight you will see plastic tangs on both pins, use a tiny flatblade screwdriver to pull tang away from pins and pin will slide out. Be sure you mark which side the colored wire came out of , you will want to insert the colored wire on new light in same position on old plug. Pins slide in and lock onto tangs , then reinsert red lock into plug and your done. Havent installed in truck yet testing with a 12 volt battery they seem brighter then the 7 year old ones , i will treat them with UV protectectant before i reinstall.
Jk
Sent from my SM-G950U using Tapatalk
