2017 M&R Ford Raptor Fog Kit Prototype
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
Here is my understanding of the beam patterns. Flood produces a very broad and short dispersion of light. Spot produces a much narrower beam that projects a fairly long distance. Euro produces a beam of light somewhere between flood and spot (much broader than a spot beam and projects much further than flood, but probably not as far as spot). For on-road use they recommended using spots and pointing them downward to minimize oncoming driver glare.
As for why I am separating the amber lights, I was thinking the separation would create in interesting visual look instead of placing them side by side. I would love to hear what others are planning on doing.
I'm planning on having mine like the pictures M&R provided... from inside to out
Amber spot, amber flood, white spot, white spot, white flood.
I'll have the ambers on one switch and the whites on another.
Jeff-Ohio
Cincinnati
I could be wrong, but I'm guessing that moving the lights around isn't that difficult to do, so if you don't like how things look, you can always play with the configuration until you get something you like. With the mix of lights that I ordered, I should be able to put something together that I like. Hopefully I get it right the first time.
MandR Automotive
MandR Automotive
You are absolutely correct
Jeff-Ohio
Cincinnati
Do you have pics from behind the bumper showing how the mount attaches to the bumper, how the lights are attached to the mount, and how the angle of the lights can be adjusted?
Jeff-Ohio
Cincinnati
Still hoping you can satisfy this request. I think it will go a long way in helping you sell your product.
MandR Automotive
MandR Automotive
Sorry boss here are the pics from the inside. Dont mind the horrible welded prototype :) Product will be nice clean and powdercoated
You can also see how they lights are mounted and how you have slight movement to aim them slightly lower or higher when you tighten the 2 bolts
Hemkin57
These lights look great but what is the warranty on them? I have had some bad experiences with Chinese lights in the past.
