2017 f150 365/450
Jimbo
Mad Frog Mattis
IL
You're both wrong but @Jimbo is more right than @Reptar D who likes to argue just to argue for ***** sake with no validity to his points. Such an ass hat.
2017 Ford F-150 Raptor In-Depth – Feature – Car and Driver
"Yes, folks; the 2017 Raptor is EcoBoost only and the first recipient of a second-generation 3.5-liter V-6 with twin turbochargers and direct fuel injection. Ford says the high-powered EcoBoost engines it develops for sports-car racing influenced some of the production V-6’s improvements, including a new aluminum block and updates to the fuel system, cylinder heads, and internals. To further improve airflow, the high-output engine exhales through a true dual-exhaust system with twin outlets notched in the rear bumper."
The Raptor will be the first to get this engine so it isn't sharing shit with F-150's and it is influenced by the engine they use for racing the Ford GT.
Hold on, let me cross-reference with www.horsepowerkings.com
Reptar
Jersey
not arguing for no reason, someone comes in and says I'm entirely misinformed because they lack reading comprehension? I'm going to point out where their argument falls apart.
regardless of which vehicle it rolls off the assembly line first, doesn't change the fact that the raptor 3.5 will be a lot more similar to the one that lands in the f150 for the masses, than it will the one that lands in the GT for the privileged few.
But you know what they say....
oxfordraptor
Here you go again with pure speculation to make your argument seem right. Show me where the 2017 F-150 gets the same new 2nd Generation High Revving twin turbo ecoboost. It is Raptor only so far nothing has else has been announced.
Jimbo
Mad Frog Mattis
IL
Ford says the new truck will make more power than the previous model, which was rated at 411 hp and 434 lb-ft of torque, but didn’t tell us exactly how much. It did say that the engine is a version of the 600-plus-hp mill that will power the Ford GT. It’s paired with a 10-speed automatic transmission, four-wheel drive and a torque on demand transfer case, which distributes power between the front and rear wheels.
2017 Raptor gets Ford GT - AUTOWEEK
Ironhorse07
Central, MT
ah following your buddy's approach....when you realize how you sound when you say the raptor engine will be more like the GT supercar engine than another f150 3.5 engine, revert to memes instead of valid counter points lol
To have a valid counter point one must first have a valid point. You're pompous and bloated posts are loaded with pure speculation. Simply put, you're talking out your ass.
Reptar
Jersey
Never said it gets the exact same one as the Raptor, but the f150 is getting the same new 3.5 platform that is getting tweaked for the raptor and tweaked for the GT
2017 Ford F-150 3.5L Turbo V6 Gets More Torque and a 10-Speed Automatic - The Fast Lane Truck
So because a public news article just calls the Raptor engine the Ford GT engine, it means it's the same. It's on the internet, it's gotta be true, forget even common sense lol:ROFLJest:">
What is the big deal with the 2017 Ford F-150 that goes on sale in the fall of 2016? It gets a completely redesigned 3.5-liter EcoBoost V6 engine and a new 10-speed automatic transmission. The updated powertrain means that the 2017 truck will be quicker off-the-line and more efficient down the road. Exactly how much quicker and how efficient will it be? This information has not yet been released, and we did not have an opportunity to drive the new powertrain combination
The second generation 3.5-liter twin-turbocharged V6 is new from the bottom up and inside out. It uses high-tech materials to remove weight from the valvetrain and the turbochargers. It has a new fuel delivery system that employs both direct and port fuel injection. The resulting output number for what Ford calls the “base 3.5-liter EcoBoost” is 365 horsepower and 450 lb-ft of torque. [IE the f150 gets the new base 3.5, the raptor gets a tweaked version, and the GT gets a really tweaked version] While the maximum horsepower remains the same, the torque figure grows by 30 lb-ft from the previous generation of the twin-turbo V6.
All this power means nothing if it cannot get to the ground, and the new 10-speed automatic transmission is the crucial next link in the updated powertrain. This transmission has a lower first gear and more closely spaced gear ratios to improve off-the-line acceleration and keep the engine within its optimum rpm ranges for power or efficiency. It has 6 forward “under-drive” gears, 7th direct-drive gear, and the top three “over-drive” gears.
Ford did collaborate with General Motors on the design of the transmission, but neither company specifies which components each company customized or tuned for different applications. Chevrolet chose to unveil their version of the 10-speed automatic transmission in the high-performance 2017 Chevy Camaro ZL1
A tweaked version of the 3.5-liter EcoBoost V6 and the 10-speed automatic transmission will also be used in the upcoming 2017 Ford Raptor. Ford calls the Raptor version of the engine “high output”. Ford did not announce the specifications for the Raptor version of the engine. Ford also did not comment on the future availability of a turbo-diesel or electric hybrid powertrain options for the F-150.
We have an “Everything You Ever Wanted to Know” video interview with the experts right here.
Reptar
Jersey
Ok there we go, so F-150 gets a new engine, but it's not the same as the High Output Raptor engine. So the race engine inspired the Raptor engine and the F-150 will get a de-tuned/dumbed down version of the 2nd gen EcoBoost what ever you want to call it.
From your link:
"A tweaked version of the 3.5-liter EcoBoost V6 and the 10-speed automatic transmission will also be used in the upcoming 2017 Ford Raptor. Ford calls the Raptor version of the engine “high output”. Ford did not announce the specifications for the Raptor version of the engine. Ford also did not comment on the future availability of a turbo-diesel or electric hybrid powertrain options for the F-150."
Let's work with facts going forward and avoid all the speculation, it makes things easier.
Same page now?
You're making it sound like there were 2 independent engine projects going on separately and only coincidence they're both 3.5s. A 2nd gen 3.5 for the f150, and then a totally separate GT supercar 3.5 that was detuned for the Raptor. Sorry that's not how it works in that field.
There is one new 2nd generation 3.5 platform, that is then tweaked with several variations of it. The regular f150 baseline version, a tweaked raptor version, and an even further tweaked GT version. Still all the same 2nd gen 3.5 at heart, with varying levels of changes to it.
Also just because ford dropped the news in a certain sequence, doesn't mean that's the order they came about behind the scenes.....rather a sequence that is best for the press.
GT is announced with a new 3.5....WTF? Guess it's good if it's in a supercar
Raptor is announced with a new 3.5....WOW, the Raptor is getting a GT engine!
F150 is announced with a new 3.5....WOW, the f150 is getting a Raptor engine with a couple less ponies
vs.
F150 isannounced with a new 3.5....big whoop it's already got a 3.5 now
Raptor is announced with a new 3.5....big shoes to fill, it's just another f150 engine
GT is announced with a new 3.5....WTF they're putting an f150 engine in the GT?
See what I mean?
