you can use octane booster to compensate on the fuel quality .
Bad Idea, if your not consistent with spark plug changes you will notice Octane booster often leaves a heavy coat of orange/red deposits on the spark plugs and 02 wide bands. This will foul the plugs and skew the sensor readings. This build up can lead to a misfire. Also not to mention if this is what ends up on your plugs and 02's after being being burned it means your fuel pump filter and fuel filters are being contaminated probably as well.
To Boost Octane I will only ever recommend to mix Sunoco or VP Racing fuel 100-104 UNLEADED Octane fuel, lightly. Like a 5:1 Ratio (91/93: Race fuel) This is the only true way to safely raise octane levels in a street vehicle.
If you use octane booster I recommend you change your plugs after each tank of fuel ran. You will see evidence of the red/orange coating I am warning you of.
JimIII
