I did put the engine to use this month + it was pretty dusty under there. @Yukon Joe was your fuse box pretty dusty?
I think this is the same thing that happened to @Yukon Joe at the Snowball this year.
I have a theory that it wouldn't happen if the ears weren't sprung causing and intermittent arc. I think Joe had his fuse box replaced.
at 20 degrees out, I wasn't looking for dust, hahaha...
yup, exact same thing happened to my truck. I wish I would have know to check the fuse, it would have saved me a lot of heartache. My truck would cool down enough, that it would make contact. Then I'd run it for a bit, and it would get hot and the melted fuse would brake connection and stall out. Then wouldn't start until it was cool again.
Where you running AUX4 at the time that it cut out? Did you run AUX4 before you had parked it last time?
I think mine has to do with an aftermarket 10 amp fuse that I used in the Aux 4 location, fuse 28. It had larger (thicker) fingers than the stock mini fuses and cause some possible cross arcing. I was funning AUX4 the whole time, those are my rear facing ambers.
I was going to get the fuse box replaced under warranty, but came to the conclusion with the dealer, that the fix that the dealer did in Escanaba, MI was sufficient. To replace the fuse box, is to replace the wire harness on both sides of the truck. This includes locations like Horn, head light, Aux switches, many of the places where I've spliced in. The dealer was afraid that after he did the work, that Ford would eventually denie the claim. He has a done a lot of good work for me, and I trust what he was telling me. So we decided to keep it the way it was.
I did ask him to check the fuel meter or fuel regulator (not sure of the proper name right now) that is mounted under the truck. He checked the voltage and ground on it and it was ok.
So in the end, I'm not 100% sure what caused the issue. And as you can tell by the other thread regarding this issue, the other guys who had it happen to them don't really know either. There is some speculation as to the cause, but nothing definite.
please let me know where you got the mini fuses for 75 cents...
