DreamcastERA
DreamcastERA
Clearwater, FL
Well, I have installed the replacement solenoid and check valve.
I test drove it around and didn't think I heard anything. I popped it into 4WD and then back into 2WD to test that out - and shortly after going back into 2WD it made the sound again.
I came to a stop and then set off again. Sound was gone once more.
After that I tried to put a little bit of load on the engine by manually locking into 5th and 6th gear at ~40 mph and giving it maybe 3/4 to full throttle - which did cause the sound to occur aggressively and repeatably. I had to entire a round about and upon coming out the other side I tried again, and was not able to replicate the noise.
If anything it seems to be happening less consistently, but it's really starting to drive me a bit insane
After letting the truck sit, I checked the reservior for vacuum, and it had none in it - seems like bad check valve again.
UPDATE:
I have since driven the truck again after letting it sit for ~20 minutes. I tried locking into 5th / 6th gear again and was unable to reproduce the issue. In-fact no matter what I did I could not reproduce the issue on this drive. Quick note: My vacuum reservoir now seems to hold its vacuum - but as soon as I shut the truck off, my hubs engage and they lose vacuum. The hubs lose vacuum, despite the fact that the reservoir still has vacuum in it. SO seems like that means I have a break in my lines somewhere.
Once I turned the truck on , I ofc had no issue and was not able to replicate the problem.
UPDATE 2:
I pulled the skid plate off and discovered that you can pull enough vacuum to disengage the hubs with your mouth, so thats something! I went ahead and tested the flexible hose on both hubs and they each worked and held. However, the passenger side looked like it had bee repaired before by some electrical tape so I removed all of the tape and tested each piece individually, zip tying a couple suspect areas. They held just fine afterwards. I then tested the plastic line that links both hubs together and connects them to the solenoid (I disconnected the driver's side from the hub and tested from there), but it did not hold. I then pulled my skid plate and checked the plastic line that runs across the frame and found no issues. After I was satisficed, I checked the last spot - the connection to the solenoid. The plastic line that connects the hubs to the solenoid broke off as soon I removed it - so that was a potential leak point as well. I repaired that and then I noticed something interesting (which may be common knowledge): the solenoid dumps all vacuum to the hubs after maybe 10 seconds after turning off the truck. I tried the old one and it has the same behavior. Not knowing that this was normal has made diagnosing this issue very difficult, because I expected the truck's hubs to stay UNLOCKED when the vehicle was turned off in 2WD IF the vacuum reservoir still had vacuum. Regardless - the issue has not returned! I even marked the front axle and the hub to see if they moved at all during my drive, and they were in the same spot when I get home as when I left. My truck does make a sort of moaning/groaning sound when coming to s top but that seems to be brake related. It may have been making this sound for a long time, but I haven't had a reason to pay such close attention until recently. Perhaps I fixed a leak somewhere along the way, or maybe the new check valve had an intermittent failure (maybe once it actuated a few times it worked itself out. If it did have intermittent failure, that would explain why there was no vacuum in the reservoir after my initial test drive, and potentially also the sound.)
Point is, it appears to be fixed now! The lines are all brittle feeling, so I'm likely gonna replace them all with something less failure prone when I get home. I still appreciate all of y'all's help! The real test will be on the highway when I head home, but so far it seems to be in working order.
CoronaRaptor
CANADA
Yeah, the hubs are suppose to engage when the truck is off, been that way for years. That's why these trucks are suppose to be flatbed towed if they break down. Glad you found the source of your problem, happy motoring now!
DreamcastERA
DreamcastERA
Clearwater, FL
I would be surprised if the differential is not severely worn and damaged due to only one axle being engaged. When one axle is turning and the other is not, the differential side gear on the engaged side will be spinning at wheel speed, along with the pinions. The opposite side gear remains stationary. These gears are only designed to accommodate for wheel speed differences when turning, and not for one side spinning at road speed while the other remains stationary. When the side gears wear, the axle will exhibit radial movement, which destroys the axle seal and causes an oil leak.
As far as the IWE replacement, it is critical that the Ford published service procedure be followed. I’ve seen far too many repeat repairs due to improper installation. The wheel hub nut (axle nut) must also be replaced as well, they are not reusable once removed.
It's been ages, but I thought I would let you know that I ended up selling the truck. Before I did, however - I can confirm that you were correct, the diff was severely worn out. Carrier bearings most obviously, but it ended up needing to be entirely rebuilt. Even though I ran new silicon vacuum lines, and got rid of the noise, it was only a band-aid, the real damage had already been done! I ended up trading it in without rebuilding the diff.
mprice1234
SVT Gen 1 Rules
Colorado Springs, CO
So, you passed the buck to someone else to get screwed with a totally wore out differential? Nice! Hopefully you replaced it with a Pink Prius.
DreamcastERA
DreamcastERA
Clearwater, FL
I traded it in to a dealership, told them about the issue, as well as giving them all of my maintenance records. I also paid over $2500 to fix an AC evaporator issue days before trading the truck in. I could've just filled it with freon. No need to assume the worst and insult :)
