GEN 1 2013 Moonroof
GTC-NOVA
I really appreciate some help here:
The problem I have is what most of you have experienced...(entire Ford lineup where a moonroof is installed): #Moonroof Failure.
1. Does anybody know a "decent" shop in the Northern Virginia that specializes in removing old moonroof hardware and installing new hardware? I have the new kit (rails, brackets, track, etc.) Glass, motor are OPK! I say "decent" because so far I heard that nobody wants to do this for less than $1K...! Hard to swallow!
2. When doing this do you have to remove the entire headliner, door rubber sealers, chairs...? I have seen some videos and basically most of the cabin comes apart...And all this just to replace the hardware for the moonroof?
Any helpful feedback, hints, or related information is of Great help!
CleverGirl_
Cabin Clown
Just follow the YouTube videos or search for threads on here
No need to make another one
Cheers.
GTC-NOVA
GTC-NOVA
Cheers.
As much as I would like to say <<thank you>>...I am asking myself why did you bother to respond...as you did not provide any help.
I understand you are THE "CleverGirl...but c'mon...where is the "clever" part?
kocher93
CA
If you've seen videos on how to do it, that's about it. Trucks been out for 11 years the process hasn't magically changed.
The Moonroof is under the headliner and the headliner is under all the other trim.
Try not to break any plastic trim while doing it is all I can say
GTC-NOVA
GTC-NOVA
"The Moonroof is under the headliner"
Actually the moonroof sits above the headliner...this is why I was asking the question. Can this job be done from the top, without removing the headliner and the rest of the trims?
CleverGirl_
Cabin Clown
The clever part is knowing how to use the internet I suppose.
Best of luck.
kocher93
CA
Under as in layers, if you can't infer that I don't know what to tell you. Pull all your panels, try not to break 11 year old plastic and replace the broken pieces and never use it again.
