2013-2014 Raptors Sync 2 -> Sync 3 Upgrade
okieff218
Oklahoma City
I’d call 4D Tech and talk to Steve. Ask him if they can figure out a way to get it to work with v3.0. They do have an understanding of the programming to a degree but seems to me that they would build some goodwill by figuring this out.
I talked to someone at 4d. Not sure if it was Steve but he said, “Believe me if it was possible, we would’ve done it already.”
RC51TOFUMAN
in Thee OC
According to CameraSource if you use their module and front camera combined with the sync3 it will work.
I have been waiting for others to do this mod/upgrade
It's been soo long I am not sure if anyone has done this
Sidenote It's odd that some Raptors still retain the front camera that has been previously stated
Sent from my SM-G950U using Tapatalk
rkneeshaw
Northern Michigan
Ok I've spent a good amount of time on research and its time to dump it all somewhere:
Sync 3 will work on 2013-2014 gen 1 F150's with the exception of two things:
1) The temperature overlays do not work due to apparently older hardware (https://www.fordraptorforum.com/thr...nc-2-sync-3-upgrade.53752/page-7#post-1276487)
2) The front camera only apparently works on Sync 3 version 2.0 and 2.2, it does not work on version 3+.
There is a possible solution to the camera issue:
Truckzor
Try reaching out to Tricia at camera Source. I spoke with her. Here is a copy of the email
Sent:*Wednesday, May 9, 2018 10:51:31 AM
To:*[email protected]
Subject:*Camera-Source info
*Hi Tyler,
I spoke with one of our engineers and here is what you would need to do*
to retain a front camera on your 2013 Raptor.
Multi-cam interface:*
https://camera-source.com/accessori...e-for-8-ford-factory-display-radios-2130.html
and
Front camera:*
https://camera-source.com/automotive-cams/ford-font-side-cameras/ford-raptor-front-camera-kit.html
The multi-cam interface will be plug and play with the SYNC 3 radio.*
You will swap your factory camera for our Raptor camera and run the*
harness to the multi-cam interface. The interface will power the camera*
and create the RCA connection for the front camera.
Take a look and please let me know if you have any questions.
Thanks,
Tricia
Camera-Source
888-844-9763 ext 1
Those that have gotten the camera to work with version 2.0 or version 2.2 sync 3 systems have done so by:
Off-road mode, pulled the diff lock, and hit OK to enable. I put it in reverse for two seconds then to drive.
Ordering Parts
So with that out of the way, and if you choose to proceed, you need to order parts.
You can order complete kits from infotainment.com (https://www.infotainment.com/products/myford-touch-sync-2-to-sync-3-upgrade) and 4dtech (https://www.4dtech.com/13-14-ford-f150-sync-3-upgrade-for-myford-touch/).
Or, if that's too rich for your blood, you can source the parts on your own. You will need:
1. Sync 3 screen
2. Sync 3 APIM (sometimes attached to the back of the screen, sometimes they are sold seperately)
3. GPS Antenna
4. Working copy of ForScan (www.forscan.org) with OBDII dongle/cable
5. Updated USB Hub that supports Carplay (your existing hub can be kept if you don't care about CarPlay) and associated trim bezel and wiring harness
Sync 3 screens come in two configurations: Recess mount or Surface mount. If you want a truly bolt-on affair, you will want to obtain a recess mount screen. You can get a surface mount screen to work but you have to modify the mounting brackets to get it done.
The APIM comes in two flavors: Nav and non-nav. It seems the best way to tell visually is based on part number. It seems NAV APIMs will have the letter C as the second-to-last character in the part number. This isn't 100% the only way to get a NAV APIM, but I have yet to see a non-NAV APIM have a letter C in the second-to-last position.
Someone started a google sheet of part numbers you can use for reference that might help your search: https://docs.google.com/spreadsheets/d/1sPYdxO3XHZ1Uz1LngcQpIj4Xu-vDu1yzZyr_B1ueGwM/edit?usp=sharing
I've found most stuff on ebay is pretty pricey, and I think thats the first place everyone looks. I had good luck searching on car-part.com. You'll want to look for a "GPS Screen" for probably 2016 or 2017+ ford vehicles. Look at pictures, request pictures, or check part numbers to make sure you are getting a screen AND the APIM (or at least are knowingly getting them separately)
Speaking of, these ford vehicles had recess mounted sync 3 screens: Edge, Explorer, F250, F350, Flex, and Taurus. The rest (including F150 and mustang) had surface mounted sync 3 screens, and while they will work, you will have to modify your mounting brackets.
So what i did, for example, is searched car-part for 2017 explorer GPS screens, found one for cheap, requested pictures, verified it had the APIM on the back and validated the part number against the google doc worksheet for NAV APIM's (because I wanted NAV), or at least I confirmed it had a C in the second-to-last position of the part number, and placed my order.
The GPS antenna is found on Amazon: https://www.amazon.com/dp/B006AKVX2S?tag=viglink20295-20
Visit www.forscan.org to see a list of compatible OBDII dongles/cables. However in my case I'm using a windows laptop and ordered the OBDLink SX USB cable because OBDLink is good stuff. (https://www.amazon.com/gp/product/B005ZWM0R4/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1). You will need an "extended license" for forscan, and currently its a 2 month free trial that can be renewed as often as you like, it only requires you register a forums account.
If you want Carplay to work you also have to replace the USB hub in your center console. The part number you want is HC3Z-19A387-B. And if you have the Sony system like I do with the A/V inputs then those will go away and you also need the bezel for the USB hub part number GC3Z-19C149-A. To connect the new USB hub to your existing wiring harness you will either need to splice your own in with part number WPT1239, or for a true plug-and-play experience you can buy one pre-made from 4dtech (https://www.4dtech.com/sync-3-retrofit-usb-hub-wiring-adapter-gen-1/).
Installation
Now that you've gathered your parts, you get to install them.
This is a great video that shows the process:
And once you're physically installed, now you get to program the unit using ForScan.
I haven't personally completed the programming process yet, so I can't give you details on that yet. But these threads have been a great resource for me until now and do explain some of the forscan programming process too:
https://www.f150forum.com/f38/2013-sync-2-2017-sync-3-conversion-attempted-372943/
https://www.f150forum.com/f38/guide-13-14-mft-8in-screen-sync-3-android-auto-carplay-373769/
https://forscan.org/forum/viewtopic.php?f=16&t=4393
I also felt this post was informative and helpful regarding the boot up screens available with sync 3:
Here is some interesting info I found on the fusion forum about the mod. Pretty sure these options would be accessed with the FORscan tool.
ALTERNATIVE VISUAL THEME CHOICES
Visual Theme Variants:
7D0-03-01: xxxx 00xx xxxx - Ford Classic (Blue Theme, Multi-colored Buttons/Knobs)
7D0-03-01: xxxx 01xx xxxx - Ford Timeless (Blue Theme, Blue Buttons/Knobs)
7D0-03-01: xxxx 04xx xxxx - Ford GT (All Blue Theme for 2017 Ford GT)
(These Require Lincoln Master Enable Below)
7D0-03-01: xxxx 02xx xxxx - Lincoln Timeless (Gold Theme, Black Icons)
7D0-03-01: xxxx 03xx xxxx - Lincoln Next (Gold Theme, White Icons)
Lincoln Theme (Master Enable):
7D0-01-02: 8xxx xxxx xxxx
Note: Car MUST be power cycled to see theme changes. Let vehicle sit for 2 minutes before turning back on.
ALTERNATIVE SPLASH SCREEN CHOICES
Splash Screen Variants (2.0+ Software Required):
7D0-02-01: xxxx 01xx xxxx - Ford / Lincoln (Default)
7D0-02-01: xxxx 05xx xxxx - Raptor (Ford Performance)
7D0-02-01: xxxx 08xx xxxx - Vignale
7D0-02-01: xxxx 09xx xxxx - Shelby Mustang R1 (Ford Performance)
7D0-02-01: xxxx 0Bxx xxxx - ST (Ford Performance) - Sport Technology
7D0-02-01: xxxx 0Cxx xxxx - RS (Ford Performance) - Rallye Sport
7D0-02-01: xxxx 0Dxx xxxx - GT (Ford Performance) - Grand Touring
Note: If you pick a different Splash Screen... it will always show the Lincoln Splash Screen on power off if the Lincoln Visual Theme is enabled. Just an FYI.
RC51TOFUMAN
in Thee OC
Ordering Parts
1. Sync 3 screen
3. GPS Antenna
Installation
Now another question will be can the Nav TV Motion Bypass be connected to all of this ?
RC51TOFUMAN
in Thee OC
Apparently YES there is a Motion Lockout / Front Camera / Rear Camera FORCE ON option.
This wasn't available a year ago when I was looking but I guess YES IT'S AVAILABLE NOW.
checkout Naviks link
https://naviks.com/i-24076363-2016-...ce-force-oem-rear-camera.html?ref=brand:97234
or
https://naviks.com/i-24076072-2016-2018-ford-f-150-sync-3-360-camera-system-video-interface.html
Who want's to piece it all together...to see if we have a working product?
-4Dtech or Infotainment
-Naviks Motion Bypass / Front / Rear Camera force
-Camera Source Module
i messaged Noah (thecarstereo) awaiting his reply. He knows the audio / electronics pretty well on our trucks.
rkneeshaw
Northern Michigan
Completed my conversion today and got everything working (sync 3 version 2.2):
Overall it wasn't too bad. Huge thanks to @tock for sending me his APIM AsBuilt configuration. I updated it so it uses the Ford startup screen. I have a 2013 supercab with heated and cooled seats, backup camera, rear parking aide, and Sirius XM radio. I had to make just a couple tweaks from what tock sent me, here is what I'm running right now:
;Block 1
7D0-01-01 AA21 0403 02AD
7D0-01-02 0A89 0050 0AC7
;Block 2
7D0-02-01 5553 0103 40C8
7D0-02-02 8200 8000 00DD
7D0-02-03 0005 E1
;Block 3
7D0-03-01 0000 0403 00E2
;Block 4
7D0-04-01 0100 1100 2D1B
7D0-04-02 0004 E1
;Block 5
7D0-05-01 198C 198C 2E55
7D0-05-02 0EEC
;Block 6
7D0-06-01 805E
;Block 7
7D0-07-01 0A00 3300 001C
7D0-07-02 0000 0EF9 00E7
7D0-07-03 0056 5684 0011
7D0-07-04 694B
For my media hub I used the premade plug-and-play adapter from 4dtech and it made everything super simple
I'll probably attempt to get this upgraded from version 2.2 to 3.0 in the next week or so
j2k
Belleair Beach, FL
@rkneeshaw - Would you mind sharing what your ballpark final cost was? I'm just curious about the savings versus purchasing one of 4dtech's complete plug and play packages.
rkneeshaw
Northern Michigan
I bought the screen and APIM for $260 off car-part.com, and spent maybe another $100-$150 on odds and ends (USB hub, cable, forscan cable, etc). So around $400 all in I think.
jgwoody
For those with front camera, I can confirm it works on versions 3.0 and 2.3 as well. The only issue is it uses the rear camera delay, which only works up to 5mph unlike the original front camera setup which worked up to 15 MPH. Still better than nothing.
To turn on camera delay:
Sync settings > vehicle settings > camera settings > turn on “rear camera delay”. Now when in 4-low or off-road + locked diff, it works after going into reverse then drive.
Members online
96,401
60,331
JaytheGreat90
