2012 Knock/Chirp on cold start
vtwinjunkie
va
Yea. Its odd because my truck just turned 70k miles. Certainly not high mileage.
If its normal I might just switch to 5w30, but if not, I still have a full warrantee so I may take it in.
MTF
Celebration, Florida
I Switched to 5W-30 and it did help with the three second tapping at startup.
Plus gained .05 mpg. to boot.
I recommend using
They do have a high milage version of the extended performance oil if you want to use that.
And either Ford performance oil filter or Mobil 1 extended performance oil filter.
vtwinjunkie
va
@FordTechOne
Have you seen this alot on the 6.2's over the years?
I actually still have a really good warranty left so if it is an issue I'd take it to Ford. Only happens in colder temps. (below 40 ish)
