2011 Supercab homologation
KaiserM715
Kaiser Söze
Houston, TX
Can you personally make hardware changes to get an increased GVWR? Yes. Can you get Ford to "homologate" or certify it? I seriously doubt it.
Joe$
Albuquerque NM
There is a couple of companies that sell a rear suspension air bag helper or add a leaf or something similar that. Unfortunately I cannot recal the name of the companies.
Do you have to prove you can tow that much because the raptor has the power it could tow a small house lol. The suspension would blow out eventually. Maybe you can get a normal f150 rear suspension to pass the swap back.
I like the truck though. Good luck.
SlimChaChi
NJ
Hi, no clue about **** location...
---------- Post added at 10:05 PM ---------- Previous post was at 10:04 PM ----------
Damn autocorrect!
RaptorScrew
Oronoco, MN
No worries - I found it:
Welcome to the chaos!
mike.s
Well-Known Member
Damn autocorrect!
Is that like gaydar?
woutvc
Belgium
I can see he's from Belgium too.
So Homologation is just the process to get a US import car to be legal in Belgium. There are a few changes to US cars that need to be done, in order to have a road legal car in Belgium (and Europe).
You need a rear fog light is one of those rules.
But I can see it's already on dutch license plates, so it's already imported then in the Netherlands?
I don't think you can change the max tow capacity.
I also remember that the SCAB had a lower tow capacity then the SCREW.
So perhaps you should get a SCREW raptor instead of a SCAB.
Another tip, there are good companies in the Netherlands to do the homologation for you, saves you a lot of worries.
