MagicMtnDan
I told you it was dirty:
Here you can see just how crud-encrusted the filter was. Good job filter!
You can see that my factory-provided filter is the same height as the Purolator filter:
Here you can see inside the bottom of the air box. I spent some time cleaning the grime and dirt out using paper towels with degreaser sprayed on them (not into the air box). I thought I could use my shop vac but it wouldn't have been effective so I resorted to hand labor):
And here's the underside of the air box cover. Not much cleaning was required - most all the dirt and grime will be in the lower air box housing. You can see the tabs (on the left side) of the air box cover in this pic. The tabs are inserted into the right side of the lower air box housing which secures the right side of the cover. The left side is secured by the three spring clips.
I got a surprise "gift" when I was removing the air box cover. I saw something in the space to the right of the air box cover. Once I removed the air box cover I could use my fingers to pick it out of the space. I'm guessing my Ford dealer's mechanic left me a "present" of this black screw cap (screwdriver shown for scale
). Anyone recognize this cap? I'm wondering if it's an oil container cap...
Somehow it happened
Pics or it didn't happen Coyoteman. :banana:
Somehow it happened
