GEN 2 20” Wheel Question
GR8Ride
GR8Ride
Upstate New York
Great news! Thanks a lot! I ordered the upgrade wheels as I wasn’t sure what it would take to get the look I wanted, so if I had to wait awhile the look would be ok. I will now cancel them on my order.
Really nice I don’t even have to level right away!!
Thanks again!!
Nick@Apollo-Optics
Thanks! Nick sent me a PM.
The question that can’t seem to find the answer or verification on what is needed to do to the truck to switch from 17’s to 35x12.5x20 +12mm. Planning to level the front end...will that be plenty of height?
If so, What would be best to level the FE that’s a good proven product?
Thanks!!
It just depends on your tire choice more than anything. If you stick with K02s, you probably won't have any rub. With Nitto Ridge Grapplers or Toyo RTs, you will get some rubbing at full lock. However, this can easily be fixed with perch collars or minor trimming on your fenders.
GR8Ride
GR8Ride
Upstate New York
Thanks Nick.
Anyone running the 35x12.5x20 with a +12mm off set in KO2’s or Nitto Ridge Grapplers without leveling that can help answer if you have rubbing at full lock??
Thanks!!
Raptor18Actual
I have the VR 601s w/Nitto Ridge Grapplers at stock height. The rubbing at full lock is minor, but since you're leveling, won't be an issue.
Rhinomax
Georgia
Nick is the man!!! He got me my wheels. I have trail graps on mine. 35x12.50x20
At full lock I get a small amount of rubbing. Nick can this cause a problem if I don’t do anything about it? Love the wheels. Thanks
GR8Ride
GR8Ride
Upstate New York
Thank you for this as I may not level for a while after the tire and wheel change.
GR8Ride
GR8Ride
Upstate New York
Absolutely beautiful truck! What color is your truck? I have a feeling it’s not available anymore.
Also, do you have a front to back pic to that will show how far the tires poke out from the fender and is it about 2”?
Thanks a lot!
Raptor911
Ashburn, VA
Lead foot grey and it is not available anymore. Wheels are 1.3 inches pushed out.
Thanks a lot!
