17 x 9 with 18 offset
Kperatt09
COLORADO
Here are some pics of poke close to the pos 18
-Yokohama 37’s
-17x9 +20
Hopefully helps you out!
I’m tried the 8.5 +0 , started rubbing driver’s side
I’ve finally found my stance, on 17x9 +12. Perfect.
Did you have any rubbing when fully tucked or lock to lock with the 17x9 +12?
Hambone
Atlanta
No issues. That being said I am running the Eibach fronts on a 37 truck. Even stock, I’m not certain it would rub. You need to also factor the tire. The Yoko X-at’s are noticeably larger in circumference than the Toyo at3’s that are currently on the truck. Both are 37 x 13.5
