Bulletnjm
Thanks man, it's always good to hear from someone who has used the set up
If your wanting to drop the rear an inch, we would reccomend using the +2 leafs and using a 1" drop shackle (we can supply both) Pinion angles would have to be measured and you would most likely need to shim the leafs/axle to acheive proper pinion angle. You would not have any issues on mid-perch.
Could you weigh in on the above comments about ride quality? Especially in light of such positive reviews on the +1's I've read?
DP
+2 deavers will lower your truck about 1/2" after a few months the deavers will sag and your truck will be 1-1.5" lower than stock. or atleast thats what happened to my truck that recently received the nick name squatty...
I have the +1s and mid perch the ride is much better than stock better rebound and no axle wrap, I'm happy with it. It sits level but now that I'm looking to go 37's I'm thinking +3's.
[/COLOR]
Thanks for the write up. What shackles did you use? Any ride issues like those described above?
DP
---------- Post added at 08:56 AM ---------- Previous post was at 08:55 AM ----------
Awesome. No binding issues? You running no block and 35's right now?
Thanks again everyone for the input.
Dave
