2014 Raptor Dead, No Power
Spritle
Clear Lake, TX
2014 Raptor w/15k miles died on me today when I left work. Went to get in, fob not working. Tried the keypad, no lights. Unlocked with the key, no lights came on (dome, dash, etc). Stuck the key in and still nothing. Tried to jump start it and still nothing. Truck is acting like it doesn't have any battery in it.
Any ideas? Anyone ever experience something like this? I've been googling, but so far can't find anything like my situation. I do have a light bar and D2's hooked up to the upfitters, but they were put on a few months back. Soldered connections with shrink wrap coverings. Checked the connections for chaffing and all looked good. No other mods.
Headed back tomorrow with a new batter hoping that works. Kicker is it's in my parking garage in Downtown Houston with a 6'10" clearance. Not sure what I will have to do if it needs to be towed.
Any help is appreciated.
-Rob
Prybar
Anchorage, AK
I'd call Ford. Your truck is new enough it should have roadside assistance still.
Spritle
Spritle
Clear Lake, TX
I will have to tomorrow if the new battery doesn't fix it. Just not sure how it can be towed out of the parking garage. The truck only clears by a few inches.
CoronaRaptor
CANADA
Gotta be a loose connection, like a ground somewhere. If you turn the headlight switch, will they work? Do you have a voltage meter, put on the terminals and see if you have voltage, around 10 or 11 vdc and u r okay.
Have you tried removing the battery cables and reinstalling them?
have you tried to disconnect the battery yet? i would remove the cables and let it sit for a couple minutes. then attach the cables back. if you see a small spark when connecting the cable, then you have a good power and ground, which means your problem will lie elsewhere
