Ford Performance Tune for Gen 3s
ZaneMasterX
Mountains
Can someone verify if the calibration tool can actually change the tire size because according to this it cant be adjusted.
Gary Gere
whitefish Montana
The tool allows you to read and clear Diagnostic Trouble Codes and adjust the tire size and axle ratio stored in the PCM, clear certain adaptive learning, and perform engine off/engine on diagnostics.
You can also display up to 6 "gauges" on the supplied tool, and there are at least 30 of those "gauges" you can select, such as air/fuel ratio, spark timing, rpm, various boost / vacuum / other sensors, waste gate operation, etc. and it comes with a suction-cup device to mount the unit on the windshield.
Jesse1983
York, PA
have it yet?
ETA: also has anyone dyno'ed this yet??
Yep - I installed it yesterday. As others confirmed, self-install is a breeze. The install instructions are spot on and the process is very fast.
I haven't put many miles on it, nor have I engaged sport mode yet, so my impression so far is very limited. But, again consistent with what others have reported, I did immediately notice how smooth the truck feels now. It really floats in both up and down shifting. I'm especially excited to see how the downshifts are in sport mode, becuuse prior to the tune the truck would really buck when cycling down.
Will report back again in a week or so with a more definitive opinion.
ZaneMasterX
Mountains
Just bought the tune from Ford because my points were going to expire. They also have a 15% off code currently on accessories. With my points and the code I got it for $550 out the door. More than I wanted to pay for 26hp buuuuuuuuuut here we are. Just want the TCM tune and to change my 35s to 37s so my speedo is correct.
Donmatteo
Santa Clarita / Coronado
You will love the transmission after it.
Also, you notice the tune more in sport mode. Normal you notice the trans more.
ZaneMasterX
Mountains
Anyone have a fix for gauges not showing up on the procal 4 unit? Installed the tune and everything yesterday, setup some gauges, everything worked but then I unplugged the procal 4 while the truck was off to mount it in a different location but now there are no gauges present in the tuner except MISC which only shows the 4 tires pressures. Super weird.
SOLUTION: If your Procal 4 decides it doesnt want to show gauges in the gauges menu go to the main menu and hold down the settings button for 5 seconds and itll reset the settings in the Procal 4.
Jesse1983
York, PA
Haha I never found the gauges in the first place
