IWE nightmare...Your thoughts?
McM
Long Island, NY
So I brought my 2020 to the dealer for front end noise and told them I think the IWE's were bad. Noise went away when shifting into 4AWD. I told them I don't want the TSB performed, I want the hubs replaced. When I called to see the progress he told they hear the noise and it is now fixed. Ended up they DID the TSB. I was not happy. I told them to put it back and that I wanted them replaced. They told me they can only do what Ford says they can do. So now I'm on the phone with Ford trying to get this done right. Have any of you went through this? Thanks
M
McM
Long Island, NY
Someone tell me if this pertains to my Raptor! Because this is the TSB that the dealer said had to be done.
24-2188
23 July 2024​
This bulletin supersedes 22-2219. Reason for update: revised Part List and Service Procedure to clarify applicable steps by vehicle application
Model:
Ford
2003-2020 Expedition
4WD
2006-2020 F-150Non-Raptor
4WD
Lincoln
2003-2020 Navigator
4WD
Markets: North American markets only
Issue: Some 2003-2020 Expedition/Navigator and 2006-2020 F-150 (non-Raptor) vehicles equipped with 4WD may exhibit grinding/clicking/ratcheting noise from the front wheel area. This may be due to partial engagement of the IWE. To correct this condition, follow the Service Procedure to remove and cap the vacuum supply line or to reprogram the TCCM and replace any worn vacuum and/or IWE components.
Action: Follow the Service Procedure steps to correct the condition on vehicles that meet the following criteria:
• One of the following vehicles:
- 2003-2020 Expedition/Navigator
- 2006-2018 F-150 (non-Raptor)
- 2019-2020 F-150 (non-Raptor) equipped with a torque-on-demand transfer case (with 4A position on the MSS as shown in Figure 2)
• Equipped with 4WD
• Grinding/clicking/ratcheting noise from the front axle area
TECHNICAL SERVICE BULLETIN
4WD - Grinding/Clicking/Ratcheting Noise From Front Wheel Area
24-2188
23 July 2024​
Model:
Ford
4WD
4WD
Lincoln
2003-2020 Navigator
4WD
• Equipped with 4WD
Parts - ESOF Parts To Inspect And Replace Only If Necessary
Service Part NumberClaim QuantityPackage Order QuantityNumber in PackageDescription
1104​
Only If Necessary​
Only If Necessary​
Front Hub Bearing (Refer To The Parts Catalog For The VIN Specific Application)
N802827-S100​
Only If Necessary (2 Possible)​
Only If Necessary (1 Possible)​
4​
Front Half Shaft Nut (2013-2016 F-150 Built On Or Before 2-Aug-2016)
N802827-S100A​
4​
Front Half Shaft Nut (2016-2020 F-150 Built On Or After 3-Aug-2016)
7L1Z-3C247-A​
1​
IWE Actuator (2013-2015 F-150 Built On Or Before 11-Oct-2015, 2013-2015 Expedition/Navigator)
HL1Z-3C247-A​
2​
IWE Actuator (2015-2020 F-150 Built On Or After 12-Oct-2015)
W706890-S439​
Only If Necessary (8 Possible)​
4​
Front Hub Bearing Bolts
HL1Z-3C247-B​
1​
IWE Clutch Ring Kit
BL3Z-7A785-A​
1​
Vacuum Lines (2013-2014 F-150)
FL3Z-7A785-A​
1​
Vacuum Lines (2015-2018 F-150)
JL3Z-7A785-B​
1​
Vacuum Lines (2019-2020 F-150)
FL3Z-3C125-A​
1​
Vacuum Hose To IWE (2015-2020 F-150)
W720613-S439​
Only If Necessary (4 Possible)​
4​
Caliper Anchor Bolt (2015-2020 F-150)
W714743-S439​
4​
Caliper Anchor Bolt (2013-2014 F-150)
W520215-S441​
4​
Tie Rod Nut (2013-2014 F-150 Built On Or Before 23-Dec-2014)
W520215-S440​
4​
Tie Rod Nut (2014-2020 F-150 Built On or after 24-Dec-2014)
W520214-S440​
2​
Upper Ball Joint Nut (2013-2020 F-150)
BL3Z-3A788-A​
1​
3-Port Check Valve (Refer To The Parts Catalog For The VIN Specific Application)
FL3Z-3A788-B​
1​
2-Port Check Valve (Refer To The Parts Catalog For The VIN Specific Application)
AL3Z-3A788-A​
1​
XG-1-E1​
Only If Necessary​
Only If Necessary​
Motorcraft® Premium Long-Life Grease
He’s right, under warranty, they’re limited to repairing the vehicle to the design configuration. UNLESS you pay them to do the aftermarket fix.
They’re not being alpha hotels, they really are trying to help. So long as they’re repairing to functional on all components, you’re good, plus the workmanship is warrantied for 12/12 independently from almost all dealers.
Use 4a more.
Worry less.
if it comes back after the warranty, revisit.
dh2002
nyc
i had a 2018 5.0 with the IWE issue, basically ford got tired of replacing hubs over and over again so the new TSB was to disable the system. If you want them to pay for it you have to do what Ford says or pay for it out of your own pocket. After 3 sets of hubs I ended up putting the IWE delete kit on and it worked fine until i traded it in.
Donovan
DC
So hold up...
If they disable the IWE system, does that mean no more 4A?
So hold up...
no, it just means the hubs never unlock so engaging 2h won’t be as economical. You can still select 2h, 4a, etc.
Antho
The front wheels are spinning the front axles but not engaged at the front differential. So it is on 2wd. Just thought that this wasn’t supposed to be done on Raptors.
