Nulldetailing
Lancaster PA
Fixed my backup camera. The previous owner apparently took the emblem off (which with the old ones breaks the tabs) and then used double sided tape to put it back on. Took off the old assembly and camera and put the new one on. I did do a test and cleaning out the connection and adding some Dielectric Grease had the factory camera working. Figured since I have the new one just go with the new one. Saved the original incase this one doesn't last for some reason.
Here's the housing I used $65 and here's the camera $40 (no programming required, it was plug and play). $105 bucks and about ten minutes.
PXL_20250312_204308024.jpgPXL_20250312_204404241.jpgPXL_20250312_205245099.jpgPXL_20250312_211342585.jpgPXL_20250312_211731516.jpg
Irregular F150
its terrain good sir!
a small town in way up northeast
View attachment 487586View attachment 487587View attachment 487588View attachment 487589View attachment 487590
Nice. I moved mine up the the gate handle and that was a bit of work lol
Jhollowell
Everett, wa
A little better on the street. I didn’t off-road it with the previous setup but it seemed to do good off-road last weekend with the new set-up.
I've tried a couple different shim stacks and never felt much difference from stock. I'd say unless you add some ports and shims to the bypass tube, you won't feel much difference. But i'm not a suspension expert.
SVT-SourCream
Kerrville, Tx
If I go to fox 3.0s or icons I can dial it in to ride like a caddy on the street and dial back for off road correct?
Sozzy12
Montana
Had to search forever. It’s immaculate, and sub 200k miles (176) which is getting rare.
Almost picked up a wrecked one with intact drivetrain for $700 a couple months ago... Someone else grabbed it before I could. Wanted to swap it into something...
