Anyone receive this software update?
James628
I have noticed the heads up for the latest sequence of updates mentioned in this thread. Havent seen this one about “air conditioning” yet. But, I noticed a new function that I definitely didnt see specified in any of the update advisories. In fact, I noticed it after the update that was described “updating system so future updates are more efficient”. I havent seen a heads up on what Im to mention next. And I drive/park the truck daily. So, not certain if Im mentioning old news, but Im optimistic Im not. The difference I see after that update: Before, to get the split screen back view where the side mirror cams are simultaneously showing images to assist with backing up with a trailer attached, one had to press/enter the pro-trailer button/mode. Then, if no trailer attached, one had to select a trailer (lie), then select the on-screen button for the trailer with the backup arrow symbol. NOW, without entering/pressing pro-trailer mode, this option appears for selection simply by placing the vehicle in reverse. Convenient, depending on the surrounding obstacles. If certain no objects directly behind and the operator only needs the side views, then its convenient. Here comes the “it would be better if”: How about the tailgate backup camera along with that split view? Yeah, 3 view split screen. Much more useful.
Anyway, once you select that option from the newly available “pro-trailer” view options available by simply being in reverse, you notice the default trailer name of “no trailer” atop the screen, along with the option to shuffle through saved trailers. Seems to be a bit of trickery for the system to access the views without having to call up “pro trailer mode”. I will gladly take it.
Now, how about that blind spot camera view called up with the turn signal? Would be nice……… without having to fiddle with FORScan. Maybe its in the pipe…..
2022 ~24k
Nohowtoplz
Illinois
This slips over your paddle shifter behind the wheel on the right side. It simulates the pressure of your hand on the wheel so that it doesn’t give you the warning message every time you take your hand off the wheel for a few seconds. It works like a charm!
I got one. It does work like a charm. Thanks.
Evasive
FL
Another update. After the update to the update process…..I actually get them more frequently.
T4RNewbie
Tejas
Last update I received was in December for the "Optimized Airflow..."
Wonder how they determine the rollout of new updates
yotesmc
Cincinnati
Is there anyway see all updates my truck has received? I purchased a 21 in Dec and have only received 1 update in January. Nothing since. I have the WiFi connected and 1am Mon-Fri scheduled.
tm965
NOVA
ive only gotten a couple of updates and i have a 21 build too. i dont think theres anything we can do about it unfortunately
