Gen 3 Aux Switch Fuse location
Specialtyperformanceparts
Reviving this thread….. For the actual fog lamp circuit, were you able to determine which fuse location it is wired to? I’ve been through the manual and cannot find any reference to it. Appreciate any insight.
Yes. If you look at the photos I posted above (Before someone else replicated the same answer and pictures answered on here months ago confusing matters) It shows in the photos of the fuse box 1 or 3 and 3 or 1.
So if it has fog lights in it from Ford. Then the 1 is 10 amps and the 3 is the 15 amps.
If it doesn't have fogs (which only the 21-23 models were available without them) then the #1 is 15 amps and the number 3 is 10 amps.
It may sound confusing so lets look at it like this-
This first picture is the 24 model.
Since they only have the fogs now from Ford. Look at the picture that says Aux 1 (Prev 3). It is 10 amps. Red fuse. That red 10 amp one is Aux 1
Then the other one that says Aux 3 (Prev 1) is 15 amps. It is Aux 3. Brown 15 amp.
The 21-23 models have this photo.
The 2 that are labeled Aux 1 or 3 and Aux 3 or 1.
It breaks down like this. If you had the Rigid fogs from Ford from the factory. The 10 amp one is AUX 1. Then the 15 amp one is AUX 3.
If you did NOT have Fogs from Ford, then the 15 amp is Aux 1 and the 15 amp is Aux 3.
So they are the same locations for the fuses. Ford just switches the wires underneath for Aux 1 or 3 depending on if they put the second pair of fogs on the Aux 1 switch so they don't waste one of your 15 amp switches.
Make sense?
John
(21-23 Photo Below)
drtibrd
Midwest
Make sense?
John
(21-23 Photo Below)
It does and thank you; however, I feel there were 6 (on / off) controls without factory fog switch and with factory fog switch there are 7. I can account for six of the fuses (albeit 1 and 3 inversion) and am trying to understand for the factory fog switch (middle of headlight control) what fuse is protecting that circuit.
