Modular Bumper Light Brackets
aFallenTree
Colorado
Hey everyone! Just wanted to share what I've been working on and see if any of you have input on the bracket itself and any changes you might suggest.
Let me know what you think!
First picture is a render of the brackets. There are left and right versions that match the curvature of the bumper.
This is on the truck with a pretty large 6 LED light equivalent in weight and size to a Baja Designs LP6. Tested them in -20*F and have had zero issues with durability and strength using a PA12-CF material. Super lightweight but extremely durable.
Bracket is designed to fit flush against the bumper with accommodations for the factory rivet nuts.
Las Vegas
It looks good. The material choice is good, and it is strong enough not to require your holes to be sleeved, which is nice.
My OCD says tighten up that internal curve to the bumper.
Depending on the area you live in you might want to switch from Torx to a Secruity Bit screw head.
What printer did you use to print these? Keep up the good work!
aFallenTree
aFallenTree
Colorado
All great points!
I really wanted to sleeve the holes but decided to test first without and redesign if I found the material lacking. Main concern without a sleeve would be end users over tightening the bolts and splitting the bracket.
Also my plan all along with the internal curve was to match the factory but felt it was adding too much material without any benefits in my simulated stress tests. That and I plan to have some brackets CNC’d out of aluminum and would have been more expensive. I might still close the gap if it doesn’t add too much in cost.
Definitely agree with security hardware if I leave the truck somewhere less than friendly.
As for the printers, I’m using the X1C from bambu labs. A few mods done to keep the camber temp above 60c. Otherwise really good printers!
Appreciate the feedback! If you want some to test out I’m willing to send some over for free.
Las Vegas
In regards to user over tightening, you might try a compression test by just printing a flat and seeing how much torque you can apply to it before cracking. Depending on your infill value you might be surprised at what you can achieve. The other option would be to increase the wall thickness to accommodate compression. I've cranked up infill to 80-90 percent for items that were going to carry a load and with just standard PLA you can get super aggressive.
Appreciate the offer for a set, I currently don't have a Raptor and am just lurking until I hope to get one later this year.
pnwobrigade
WA
I like the 1pc design, been looking at doing some LP6 with something like that. If you get some machined (alum) with black ano I’d be a taker!
aFallenTree
aFallenTree
Colorado
I’ve done a few tests and know it’s designed with enough material and strength to handle 35 foot pounds of torque without any deformation. Issue being most people don’t bother with torque specs and give it the impact gun treatment.
I over designed it slightly and I’m printing at 100% infill for the least compression in any direction with the print orientation to limit stresses on the layer adhesion when in use.
I’ve had it on my truck for a few weeks now and I’ve abused the mount a lot without any signs of fatigue or failure. So far I’m happy! Hah. Feel free to PM me if you want to talk about any other 3D print projects!
drtibrd
Midwest
Nice job with the brackets. How much room is there between the grill and the back of the LPs? Asking for a friend who bought a ‘24 and has only one inch in back and 1 inch in front margin of error for parking my garage.
aFallenTree
aFallenTree
Colorado
Hey there! Sorry for the delay. Just measured and ~2” of clearance. I have enough room on the front to move the lights back another 1/2” if needed. I also made these to be close to the bumper so they wouldn’t stick out so far. I can send you a picture if you like.
MDJAK
NY
Nicely done. Have you seen the brackets SVP, a vendor here, makes for the modular bumper? It’s a two piece unit for each side, but a bit pricey.
