Anyone install the airlift 5000 on their gen3?
avyraptor23
colorado
I have the airlift 5000 ultimate kit installed on my 2023 37 package raptor at the moment and have been driving with them for about 3 weeks. Originally I installed the airlift 2nd gen ez lift compressor with two valves to control each side independently. immediately I was very disappointed and bummed out for a few reasons. TO BE CLEAR this is my experience without any added weight exceeding 100lbs and especially with no weight added at all. First, at 5 psi which is the lowest the compressor allows, despite the bags being capable of safely being run at 0 psi, the rear end was about an inch and a half higher than before install. second, the ride quality was terrible. Every bump no matter the speed or the size of the bump, the rear end would buck aggressively and refused to travel through the full compression stroke, and the jounce bumpers are way overkill it made the front end feel softer because the weight was shifted forward given the nature of weight dispersion over a fulcrum. Lastly, the mere fact that airlifts own compressor could not meet the capabilities of their bags ie being run at 0psi made me feel like a clown for not doing my research and choosing a compressor that could set pressure at 0.
Now I know Im new to the forum and some of you are probably going to say, yes obviously the ride quality would change and I shouldn’t be running the bags at 0 psi regardless of whether the bags can or not. the thing is, these are not the 1000 system, they are a 5000 system that uses the same materials for the bags as bags you might find on an f350 intending to tow a 15000 lb trailer or maxing its payload. these bags have exceptionally durable and inelastic rubber. overall unless you are hauling near max payload or tongue weight, these bags are overkill, and impact the ride quality of the raptor’s front and rear suspension to a considerable and disappointing degree.
My use case is pretty specific being that every weekend I load up my 550+LB snowmobile along with my ~100lb ramp system directly into my bed and drive up through the mountains at highway+ speeds. I hate feeling an overly light and spongy front end especially during winter on high speed mountain roads, I really don’t like the squatted look, and I want to be kind to my suspension on road so that i cant push its limits off-road and feel confident in it. occasionally in the summer I tow a surf boat, occasionally i tow lighter trailers as well, but overall the main purpose is for the snowmobile in the bed.
I chose this kit because I like the mounting location more than the 1000 kit. I like the ability to retain the marketed full droop with the cradles, I really liked that the bags could be safely run at 0 psi with internal jounce bumpers which to me meant no impact on compression performance, and I liked the versatility of what it would allow me to haul comfortably and with a level handling yet very off-road capable truck.
SO WHAT I ENDED UP DOING, and sorry for all the back story, was I swapped compressors to the Air IQ HD2 compressor which can be set to 0psi, it is very fast inflating or deflating the bags, has independent side adjustment capabilities with the two air channels, and I can see the real time actual psi whenever i open the app. at 0psi, The truck ride height front to back now sits as it did prior to the airbags being installed. the ride quality improved dramatically from the prior 5psi minimum deflation limitation, but I will not go anywhere near the assertion that it is just like stock. it is close enough to stock ride quality to tolerate for half the year, but my plan moving forward is I will remove the airbags in the spring, and reinstall them in the fall, replacing the bags themselves with fox bumps, temporarily cap and secure the airline ends, and disconnect the compressor from the battery. in my mind it will be similar to putting on winter and summer tires seasonally.
moral of the story: if you do these bags, use the air IQ HD2 Compressor. also, you should really only choose these bags if you don’t care too much about the reduced ride quality when no added weight is present, you have weight exceeding what i would estimate to be around 250+ lbs in the bed most of the time, or you can accept having to remove them and reinstall from time to time to maintain on road and off road ride quality/performance when payload is limited. I am banking on the SDI E click and shock revalve to handle the payload that i may have during the summer (dirt bike occasional lighter weight towing, rare short range boat hauling, etc.)
pnwobrigade
WA
Going to ask the obvious question - if at 0psi these shouldn’t be inflated and touching the lower mounting cradle. I don’t know the different in height at 0psi relative to the stock bumpstop but one would assume you should have plenty of suspension travel before the bag even comes into play? If so, there should be zero change in ride quality isn’t that the entire intent of the product? At 0psi it only acts as a passive bumpstop (not effecting normal travel or ride quality) and anything north of that would be a traditional airbag/load setup. Are you sure they are truly at 0psi?
OptimusPrime
Washington
I ended up ordering the gen3 airlift 5000 kit and it should be here soon. Part is 88414. I got a deal on the wireless compressor as well, but not sure I’ll install the compressor, might just stay manual and sell the compressor kit.
Just wondering if anyone has installed and if there is any feedback regarding ride comfort when unloaded and overall impressions.
How did these work out for you? How is ride quality with/without a trailer?
Hallboss
PNW
Was thinking (hoping) the same. I’m about ready to pull the trigger on these, but don’t want the normal no-load ride quality screwed up. Waiting for more reviews. :popcorn:
DansDrives
Snoqualmie, WA
Following because I'm just about to order these as well, but can wait. I fully planned to remove them when not in use just from what I know of other airbag systems.
avyraptor23
colorado
since the airbags will inevitably always hold air inside because they are a closed vessel, even at 0 psi, this means that when the bag is compressed through suspension travel the psi of the air bag increases. if i go over a speed bump or accelerate hard while viewing the air is app, which shows real time air pressure inside the bags, i will see the psi increase anywhere from 2-15 psi depending on the speed and the amount of compression. the bag does compress significantly better than if they were set to 5 psi, but the system will inevitably have an impact on the ride quality. the truck still rides about 80-90% as soft in the rear without weight. with weight the truck rides great and i would say at the right psi the truck rides about how it would noweight-stock. if you need bags, this is the best system with the air iq. if you are picky about ride performance off road or over speed bumps around town, replacing them with bump stops when needed is advised.
Hallboss
PNW
I’m wondering (if installed with manual air fill not onboard compressor) if you just take out the schrader valves at the stems allowing the air in the bags to continuously escape when going over bumps and mitigate the rough ride on highway when bags are installed. That would be much easier than removing the bottom cup or remove completely when not hauling a load.
I just ordered the kit with manual air and will try it. Yesterday I towed my box trailer with two motorcycles in it and the rear sag was horrible.
