Predator 5.2 swap into Bronco 2dr.
Oregon
Hey Everyone, I'm currently swapping in a 2023 F150 Raptor R engine and transmission into my 2021 Bronco First Edition half-cab.
Ill be posting a few updates as the project gets underway.
Also, Im curious about the oil pump drive gears upgrade...anyone done this or have an opinion?
here's pics so you know it ain't a Prius....
2020FordRaptor
Nevada
That’s going to be frickin awesome. Good luck on the swap, I know a few people have started the Coyote swap and then gave up with all the hoops they had to go through to make it work.
didnt know doing wheel stands were still a thing...... or backflips.
Torchy
Nevada
Looks like a fun project.
I’m reliably making 1030whp in my gt500 problem free. You’re probably good on the opg’s. Mine are stock and I don’t know of anyone having issues on the predators.
Coyotes I get, might need them changed if your pushing bigger power.
P
Oregon
Snagged up the "R" Vesion of the 10R80 and I bought a T-case from a Ford Everest because it's the right pattern and has drive shaft flanges, instead of the longer slip yoke built into the back of the T case tailhousing like the F150 style.
Also a few other parts arrived in the mail. Starter , wire harness, twin fuel pumps, twin Fuel-pump-modules, bolts, and other doodads.
Mostly just need the supercharger coolant pump relay and pigtails for it, Seems like most everything else in the wiring is identical or non-essential.
