GEN 3 Official Aftermarket Wheels Thread
Chilly_Chaz
Conifer, CO
I want to upgrade the wheels/tires on my 25, 37PP (hate the OEM wheels).
I've spent hours on this thread, it's very helpful. I live in the mtns of CO and need a good snow/ice tire.
My options are limited to the MT Baja Boss AT, Open Country, or Wildpeak. I'm leaning towards the Baja Boss A/T.
I want Vossen Hf6-4 20x10, w -18 Offset. Will pair this with 37x12.50x20 Baja Boss. Also, will have the Eibach springs (2.25" front, & 1" rear) installed.
With the new, modular bumper, does anyone know how much trimming will be needed to make this work? Thank you in advance!
BaseModelRaptor
DFW
Brodozer incoming.
KustomAF
Riverside, CA
I like it, I was between this and the SDI solution for leveling. SVC was recommended by the shop i used so i just went with it.
Ride is a little stiffer up front, but i am really happy with the height.
What shop did you use and how much did it cost if you don’t mind telling?
So Cal Super Trucks in San Bernardino insisted on the SVC collars when I asked about the SDI top hats. They quoted me $700 installed and aligned OTD.
BahaBlastediam
Philadelphia
Nate,
Not a good picture….but here are your wheels on a Space White. I will try to take some better ones soon.
Amazing how much lighter your wheels are vs stock 802 wheels.
View attachment 483678View attachment 483679
Any issues with the 0 offset in the stock tires? First 802 I’ve seen running both stock tires with a 0 offset wheel. Trying see if I’ll need a level
kirkb
So Cal
I am not OP, but I have 0 offset wheels on stock tires, no rubbing and no issues (even with heavy off-roading). I think most all of the trucks you see on Method wheels are running 0 offset because that is all they offered in Raptor fitment for a long time (may have other options now). They do poke a little more than stock however and will throw more mud, dirt, water on the sides of the truck.
BahaBlastediam
Philadelphia
Zero issues. I checked with a bunch of folks prior to going that route…and everyone confirmed I would be good.
Thanks! I took the leap and had them switched over and added. Really happy I went with the machined look and not black like everyone else. 17x9 0 offset Lock off road Baja on the stock 37x12.5r17 bf ko2
9AND3 Wheels
SLC, UT
