1.5” spacers - new studs needed?
St. Louis
Hey guys, bought some 1.5” BORA spacers cause I want to keep my OEM beadlocks but want them to fit about like a 0mm offset wheel.
That being said, I bought these under the impression the stock studs were less than 1.5” long and wouldn’t need to be changed/trimmed to run the bolt on BORA 1.5’s. Has anyone run these spacers with stock wheels? Haven’t had a chance to take the wheels off and I’m just curious what I’ll find.
Thanks!
pcs
milky way
if you had doubts, maybe you could have asked the company before you bought their product. if your don’t know how spacers work check out this pic. you shouldn’t need longer studs.
RennsportRaptor
St. Louis
I know how spacers work and have had numerous sets of bolt-on spacers. If the OEM studs are more than 1.5” long, they will protrude past the mounting surface and contact the face of the wheel. That gap will keep the wheel off of the hub centric ring and will allow vibrations which will eventually ruin the wheels or spacers (or both). It’s not safe.
BORA says they work without cutting/swapping studs. I was just wondering what anyone else had to say.
SVTNate
Northwest Indiana
I'm in a Gen 1 facebook group, and someone else just asked this question, the consensus seemed to be you still have to cut a little off, but I believe with 2in you don't need to.
RennsportRaptor
St. Louis
Did you have to cut the studs?
I did not. The studs protrude by tenths of a millimeter and my wheels have recesses in the mounting surface where the studs won’t actually make contact unless they were .5” too long or more.
I may eventually trim the studs just in case I’ve gotta run a spare or if I buy different wheels. With these AT beadlock style wheels it doesn’t matter.
RennsportRaptor
St. Louis
Stock size wheels and tires with the 1.5” spacers. Stock rear suspension. Mid perch with stock springs in front. Studs did not need to be cut. You may have to with different wheels.
RennsportRaptor
St. Louis
It’s extremely close - probably the width of a couple pieces of paper. I have aftermarket wheels in a stock width and offset. The wheels have recesses where these studs won’t make contact. If the mounting surface was flat I’d have ground my studs down.
