GEN 1 Front Differential/CV Axle/Stub Shaft Play and Wobble
Houston, tx
Hi guys, I've solved a lot of problems the last several years reading this forum but never posted. I have a 2014 gen 1 super crew with a 140k miles on it. I have a wobble in my truck at all speeds and a clank in the front end when going over bumps. At 5-10 mph, it feels like I'm driving on an egg shaped tire. I got them road force balanced and they all checked out. The front wheel bearing hubs don't have any play in them. They do have a slight grind to them, so I'm going to replace them. The CV axles don't seem too bad. The boots are fine, and they visually appear okay. Where the passenger side CV axle goes over the stub shaft splines on the differential side, there is a decent amount of play in there. I can push it up and down slightly and reproduce the same clunking sound. I plan to replace the CV axles because of this.
However, when I removed the passenger side CV axle, I noticed the stub shaft sticking out of the differential tube has a very very minor amount of play in it. I really can't even get it to move up and down, but I can get it to clank just slightly. Questions...
1. Is this amount of play normal, or is this something I need to address while replacing the CV axles and bearing hub assemblies?
2. Can this stub shaft be pulled from the outside, or do I need to open up the front diff to remove a C-clip? Or is the clip the same as the one on the outside of the shaft that doesn't need to be removed?
3. I'm assuming if I remove the stub shaft, I will be able to see the bearing better and will be able to pop it out and replace it?
Thanks for everyone's help! Here's a couple pics and a video of what I'm referring to.
  • IMG_9110.mov
    11 MB
CleverGirl_
Cabin Clown
I have all of these symptoms other than the clang. Mine is more of a rattle, like a fender liner not secured. But the egg shaped tires is familiar. Some of it may be normal? That’s what I tell myself anyways.
Nulldetailing
Lancaster PA
I just picked up a 2013 a few weeks ago and feel something similar. I haven't pulled the tire to check but curious to hear if you changed the CV Axles and if that fixed the egg feeling?
Gumby
Nashville
Ok to be clear. if you are running IWE.s and all of that is working correctly. in 2 wheel Hi.... None of this is spinning. any "EGG" feeling you get is Hub, Wheel, or Tire related. Now if it is only present in 4 wheel HI now you can add the CV axel shafts. IF you are running IWE delete. Bless your heart. Possibly @EricM will give you advise.
