What are your MyMode (R Button) Settings?
TXCobra
I do sport for steering, suspension and exhaust. 4A drive mode. I’d do Baja exhaust but it leaves the off road message on in the bottom of the main cluster “off road use only” and that’s usually where my song tracks are. Drives me crazy.
R
rc11
NJ
Coming from the TRX, I wish I could keep it in baja mode and 4wd all the time, but the transmission binding in 4H when parking bothers me. Understood that I can change the drive mode to 2H, but can't stomp on it from a dig without a lot of wheelspin!
Xiaofeng Mu
CA
No there isn’t - stop making things up.
Ford removed the LSD from the front for this reason on the R.
Not sure about LSD but they did remove Torson in R. My early 23 R (built in last December I believe) indeed doesn’t pull in straight if floor the gas in 4A. Hope this can be solved in my upcoming 24 R.
Rustyseatbelt
Use 4A. If you're in 4H on pavement it's just a matter of time before you grenade something. 4H and 4L should only be used off pavement.
Burt
Auburn, CA
Transmission: Sport
Drive: 2H
Exhaust: Baja
Suspension: Baja
Steering: Comfort
Performance screen with shift lights
BadWRP
Transmission: Sport
Drive: 2H
Exhaust: Baja
Suspension: Sport
Steering: Sport
rcloke732
Houston
Curious how you guys have your R Button set-up? Here’s mine:
Transmission: Sport
Drive: 2H
Exhaust: Baja
Suspension: Baja
Steering: Comfort
I wish there was a transmission mode between Sport and Baja, but other than that, I’ve enjoyed this setup the most.
I've tried to set mine multiple times and it constantly reverts back to the normal default settings.
