GEN 2 I know another FORscan post but in need of some help.
Bennett Co
Hey so basically watch youtube and did everything according to what everyone said everything is good....
Except
1. When locked not running or remote start my passenger low beam wont turn on when i physically hit the start button it will come on.
2. My bed led light switch wont work it was working before i played with settings i used the online Excel Spreadsheet i'm sure everyone else did from livin it up (or whatever)
3. smurfslayer hooked me up with a link to get the original BCM settings for stock i checked those with my settings everything appears to be legit and only changes are the ones stated in the Excel Spreadsheet.
and no the bulb is on bad it works perfectly fine
any ideas Thanks
what forscan mods, DRL?
1) Just do like Carrie Underwood - undo it.
DRL mods are the most error prone of forscan settings.
2) Does BCM have a trouble code set? try clearing it, cycle ignition and retry.
if 2 doesn't work, go back to 1.
zacharyguyjordan
Bennett Co
Yes drl mod low beam and ambers
I’ll give this a try when home
